[mapserver-dev] REST config API
Dan Little
danlittle at yahoo.com
Thu Apr 1 14:52:17 EDT 2010
Are you thinking of an AXL file?
----- Original Message ----
> From: Stephen Woodbridge <woodbri at swoodbridge.com>
> To: bartvde at osgis.nl
> Cc: MapServer Dev Mailing List <mapserver-dev at lists.osgeo.org>
> Sent: Thu, April 1, 2010 2:41:42 PM
> Subject: Re: [mapserver-dev] REST config API
> href="mailto:bartvde at osgis.nl">bartvde at osgis.nl wrote:
> Steve,
> MXD is a binary file and its format is not published, so
> this is not
> possible.
Ah! that is a problem. Searching my systems
> for .mxd files shows them to
be binary as you say.
Someone sent me
> one that was an XML document so maybe there is an XML
counter alternative to
> the binary format or maybe there is a metadata
file related to the .mxd file
> that is in XML. Anyway I know mostly
nothing about ArcMap.
Ok, so
> back to your regularly scheduled thread about REST interface for
mapserver
Thanks,
-Steve W
> Best regards,
> Bart
>> This might be a little off topic, but
>> I think it would be nice if we had a tool that could
> take mapfile and
>> generate an ArcMap MXD(?) or whatever the
> equivalent to a mapfile is for
>> ArcMap. Maybe this is nothing more
> than another XSLT file the remaps the
>> mapserver XML mapfile into MXD
> file. And may be do the same in the
>> reverse
> direction.
>> -Steve
> ymailto="mailto:bartvde at osgis.nl"
>>> Hey
> Jeff,
>>> as an example usage, Jeroen Ticheler's
> company Geocat is developing an
>>> ArcMap extension which can talk
> to the Geoserver REST interface to
>>> export
>>> an
> ArcMap project into Geoserver. IMHO, it would be very cool if
> this
>>> tool, which is not gonna be open source btw but
> proprietary, could be
>>> used
>>> against Mapserver the
> same way it can be used against Geoserver.
>>> Best
> regards,
>>> Bart
>>>> I'm following
> this thread closely (because yes it involves the side of
> MapServer we always seem to forget, the user side)...but I am having
> a
>>>> hard time picturing the end product (I don't see a link to
> a demo on
>>>> the
>>>> geoserver link that Bart
> provided).
>>>> That said, if this is really
> the next 'MapEdit', maybe we need to
> gather
>>>> some funding providers together and develop this
> MapServer REST API.
> -jeff
>>>> Jeff McKenna
>>>> MapServer Consulting and
> Training Services
> http://www.gatewaygeomatics.com/
> mapserver-dev mailing list
> ymailto="mailto:mapserver-dev at lists.osgeo.org"
> href="mailto:mapserver-dev at lists.osgeo.org">mapserver-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapserver-dev
>>> mapserver-dev
> mailing list
> list
> href="http://lists.osgeo.org/mailman/listinfo/mapserver-dev" target=_blank
