[mapserver-dev] Mapscript Raster Query Problem
geographika geographika at gmail.com
Thu Apr 8 16:29:11 EDT 2010
Hi list,
I have some Python code running on MapScript which queries a raster
layer by an input point. The following lines:
     for i in range(layer.numitems):
             print '%s: %s' % (layer.getItem(i), s.getValue(i))
With this I get the output below:
x: 249975
y: 249975
value_0: 3
value_list: 3
class: 50-100m
red: 162
green: 180
blue: 189
But no matter which points I use the class and the rgb values remain the
same. However the value_0 and value_list are always correct. I have a
hack to get the correct class based on the value, but I'd appreciate any
further clarification on why the same values are always returned. The
raster displays without problems through MapServer showing the correct
classes for each pixel.
Regards,
Seth G.
