[mapserver-dev] Compile issue - svn trunk
fruitwerks fruitwerks at gmail.com
Sun Apr 18 18:24:40 EDT 2010
Hello all
I am trying to compile mapserver on CentOS 5.4 - here is the config and
error
http://pastebin.com/HqVSR3BD
useful info...
Target: x86_64-redhat-linux
Configured with: ../configure --prefix=/usr --mandir=/usr/share/man
--infodir=/usr/share/info --enable-shared --enable-threads=posix
--enable-checking=release --with-system-zlib --enable-__cxa_atexit
--disable-libunwind-exceptions --enable-libgcj-multifile
--enable-languages=c,c++,objc,obj-c++,java,fortran,ada --enable-java-awt=gtk
--disable-dssi --enable-plugin
--with-java-home=/usr/lib/jvm/java-1.4.2-gcj-1.4.2.0/jre --with-cpu=generic
--host=x86_64-redhat-linux
Thread model: posix
gcc version 4.1.2 20080704 (Red Hat 4.1.2-46)
packages I have installed to get this far...
curl-devel.x86_64
fcgi.x86_64
gnutls-devel.x86_64
geos.x86_64
gdal.x86_64
yum-utils
proj-devel.x86_64
geos-devel.x86_64
fgci-devel
gdal-devel.x86_64
libxml2-devel.x86_64
unixODBC-devel
xerces-c-devel.x86_64
jasper-devel.x86_64
hdf-devel.x86_64
hdf5-devel.x86_64
ogdi-devel.x86_64
giflib-devel.x86_64
netcdf-devel.x86_64
cfitsio-devel.x86_64
postgresql-devel.x86_64
openldap-devel.x86_64
readline-devel.x86_64
I googled for a while and didn't find anything specific to my error.
Thanks!
URL: http://lists.osgeo.org/pipermail/mapserver-dev/attachments/20100418/32c4926f/attachment.html
