[mapserver-dev] Compile issue - svn trunk
Bret S. Lambert
bret.lambert at freecodeint.com
Mon Apr 19 02:35:19 EDT 2010
-----BEGIN PGP SIGNED MESSAGE-----
Hash: SHA1
fruitwerks wrote:
> Hello all
> I am trying to compile mapserver on CentOS 5.4 - here is the config and
> error
The ultimate error was:
/usr/bin/ld: cannot find -ldap
which means that your linker can't find the ldap client libraries,
probably; the openldap-devel you installed below includes source but not
libs, IIRC; try installing the openldap-client package and see if that
fixes that.
> http://pastebin.com/HqVSR3BD
> useful info...
> Target: x86_64-redhat-linux
> Configured with: ../configure --prefix=/usr --mandir=/usr/share/man
> --infodir=/usr/share/info --enable-shared --enable-threads=posix
> --enable-checking=release --with-system-zlib --enable-__cxa_atexit
> --disable-libunwind-exceptions --enable-libgcj-multifile
> --enable-languages=c,c++,objc,obj-c++,java,fortran,ada
> --enable-java-awt=gtk --disable-dssi --enable-plugin
> --with-java-home=/usr/lib/jvm/java-1.4.2-gcj-1.4.2.0/jre
> --with-cpu=generic --host=x86_64-redhat-linux
> Thread model: posix
> gcc version 4.1.2 20080704 (Red Hat 4.1.2-46)
> packages I have installed to get this far...
> curl-devel.x86_64
> fcgi.x86_64
> gnutls-devel.x86_64
> geos.x86_64
> gdal.x86_64
> yum-utils
> proj-devel.x86_64
> geos-devel.x86_64
> fgci-devel
> gdal-devel.x86_64
> libxml2-devel.x86_64
> unixODBC-devel
> xerces-c-devel.x86_64
> jasper-devel.x86_64
> hdf-devel.x86_64
> hdf5-devel.x86_64
> ogdi-devel.x86_64
> giflib-devel.x86_64
> netcdf-devel.x86_64
> cfitsio-devel.x86_64
> postgresql-devel.x86_64
> openldap-devel.x86_64
> readline-devel.x86_64
> I googled for a while and didn't find anything specific to my error.
> Thanks!
> mapserver-dev mailing list
> mapserver-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapserver-dev
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1.4.10 (OpenBSD)
Comment: Using GnuPG with Mozilla - http://enigmail.mozdev.org/
iEYEARECAAYFAkvL+acACgkQiP9Ks5BxbElz5gCeMDEBAHvBib3JJILwCzVWdd2R
2N8AoJe4NSKoYlIiT0DYoHJLCw5qDel1
=lxIP
-----END PGP SIGNATURE-----
