[mapserver-dev] Compile issue - svn trunk
Bret S. Lambert
bret.lambert at freecodeint.com
Mon Apr 19 11:55:06 EDT 2010
-----BEGIN PGP SIGNED MESSAGE-----
Hash: SHA1
Alan Boudreault wrote:
> Note that the missing library is "dap", not "ldap". Find the rpm
> package that provides libdap.so and install it.
indeed; apologies for the dyslexia
> Alan
> Bret S. Lambert wrote:
> fruitwerks wrote:
>>>> Hello all
>>>> I am trying to compile mapserver on CentOS 5.4 - here is the config and
>>>> error
> The ultimate error was:
> /usr/bin/ld: cannot find -ldap
> which means that your linker can't find the ldap client libraries,
> probably; the openldap-devel you installed below includes source but not
> libs, IIRC; try installing the openldap-client package and see if that
> fixes that.
>>>> http://pastebin.com/HqVSR3BD
>>>> useful info...
>>>> Target: x86_64-redhat-linux
>>>> Configured with: ../configure --prefix=/usr --mandir=/usr/share/man
>>>> --infodir=/usr/share/info --enable-shared --enable-threads=posix
>>>> --enable-checking=release --with-system-zlib --enable-__cxa_atexit
>>>> --disable-libunwind-exceptions --enable-libgcj-multifile
>>>> --enable-languages=c,c++,objc,obj-c++,java,fortran,ada
>>>> --enable-java-awt=gtk --disable-dssi --enable-plugin
>>>> --with-java-home=/usr/lib/jvm/java-1.4.2-gcj-1.4.2.0/jre
>>>> --with-cpu=generic --host=x86_64-redhat-linux
>>>> Thread model: posix
>>>> gcc version 4.1.2 20080704 (Red Hat 4.1.2-46)
>>>> packages I have installed to get this far...
>>>> curl-devel.x86_64
>>>> fcgi.x86_64
>>>> gnutls-devel.x86_64
>>>> geos.x86_64
>>>> gdal.x86_64
>>>> yum-utils
>>>> proj-devel.x86_64
>>>> geos-devel.x86_64
>>>> fgci-devel
>>>> gdal-devel.x86_64
>>>> libxml2-devel.x86_64
>>>> unixODBC-devel
>>>> xerces-c-devel.x86_64
>>>> jasper-devel.x86_64
>>>> hdf-devel.x86_64
>>>> hdf5-devel.x86_64
>>>> ogdi-devel.x86_64
>>>> giflib-devel.x86_64
>>>> netcdf-devel.x86_64
>>>> cfitsio-devel.x86_64
>>>> postgresql-devel.x86_64
>>>> openldap-devel.x86_64
>>>> readline-devel.x86_64
>>>> I googled for a while and didn't find anything specific to my error.
>>>> Thanks!
>>>> _______________________________________________
>>>> mapserver-dev mailing list
>>>> mapserver-dev at lists.osgeo.org
>>>> http://lists.osgeo.org/mailman/listinfo/mapserver-dev
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1.4.10 (OpenBSD)
Comment: Using GnuPG with Mozilla - http://enigmail.mozdev.org/
iEYEARECAAYFAkvMfNkACgkQiP9Ks5BxbEla0wCg4BaguZIXymmztOsBurteDBsf
hKAAnjWe69l06gYOh8dgoGPflWQT2DNN
=0qO9
-----END PGP SIGNATURE-----
