[mapserver-dev] Compile issue - svn trunk
fruitwerks
fruitwerks at gmail.com
Mon Apr 19 12:07:05 EDT 2010
I agree with you lol, I actually figured it out - Thanks everyone!
On Mon, Apr 19, 2010 at 10:55 AM, Bret S. Lambert <
bret.lambert at freecodeint.com> wrote:
> -----BEGIN PGP SIGNED MESSAGE-----
> Hash: SHA1
> Alan Boudreault wrote:
> > Note that the missing library is "dap", not "ldap". Find the rpm
> > package that provides libdap.so and install it.
> indeed; apologies for the dyslexia
> > Alan
> > Bret S. Lambert wrote:
> > fruitwerks wrote:
> >>>> Hello all
> >>>> I am trying to compile mapserver on CentOS 5.4 - here is the config
> and
> >>>> error
> > The ultimate error was:
> > /usr/bin/ld: cannot find -ldap
> > which means that your linker can't find the ldap client libraries,
> > probably; the openldap-devel you installed below includes source but not
> > libs, IIRC; try installing the openldap-client package and see if that
> > fixes that.
> >>>> http://pastebin.com/HqVSR3BD
> >>>> useful info...
> >>>> Target: x86_64-redhat-linux
> >>>> Configured with: ../configure --prefix=/usr --mandir=/usr/share/man
> >>>> --infodir=/usr/share/info --enable-shared --enable-threads=posix
> >>>> --enable-checking=release --with-system-zlib --enable-__cxa_atexit
> >>>> --disable-libunwind-exceptions --enable-libgcj-multifile
> >>>> --enable-languages=c,c++,objc,obj-c++,java,fortran,ada
> >>>> --enable-java-awt=gtk --disable-dssi --enable-plugin
> >>>> --with-java-home=/usr/lib/jvm/java-1.4.2-gcj-1.4.2.0/jre
> >>>> --with-cpu=generic --host=x86_64-redhat-linux
> >>>> Thread model: posix
> >>>> gcc version 4.1.2 20080704 (Red Hat 4.1.2-46)
> >>>> packages I have installed to get this far...
> >>>> curl-devel.x86_64
> >>>> fcgi.x86_64
> >>>> gnutls-devel.x86_64
> >>>> geos.x86_64
> >>>> gdal.x86_64
> >>>> yum-utils
> >>>> proj-devel.x86_64
> >>>> geos-devel.x86_64
> >>>> fgci-devel
> >>>> gdal-devel.x86_64
> >>>> libxml2-devel.x86_64
> >>>> unixODBC-devel
> >>>> xerces-c-devel.x86_64
> >>>> jasper-devel.x86_64
> >>>> hdf-devel.x86_64
> >>>> hdf5-devel.x86_64
> >>>> ogdi-devel.x86_64
> >>>> giflib-devel.x86_64
> >>>> netcdf-devel.x86_64
> >>>> cfitsio-devel.x86_64
> >>>> postgresql-devel.x86_64
> >>>> openldap-devel.x86_64
> >>>> readline-devel.x86_64
> >>>> I googled for a while and didn't find anything specific to my error.
> >>>> Thanks!
> >>>> _______________________________________________
> >>>> mapserver-dev mailing list
> >>>> mapserver-dev at lists.osgeo.org
> >>>> http://lists.osgeo.org/mailman/listinfo/mapserver-dev
> -----BEGIN PGP SIGNATURE-----
> Version: GnuPG v1.4.10 (OpenBSD)
> Comment: Using GnuPG with Mozilla - http://enigmail.mozdev.org/
> iEYEARECAAYFAkvMfNkACgkQiP9Ks5BxbEla0wCg4BaguZIXymmztOsBurteDBsf
> hKAAnjWe69l06gYOh8dgoGPflWQT2DNN
> =0qO9
> -----END PGP SIGNATURE-----
URL: http://lists.osgeo.org/pipermail/mapserver-dev/attachments/20100419/b802043b/attachment.html
