[mapserver-dev] RFC 59 Logical Expression Overhaul (preliminary draft)
Jan Hartmann j.l.h.hartmann at uva.nl
Mon Aug 9 05:47:32 EDT 2010
  This is probably something you two already have known for a long time,
but perhaps other members of this list will find it interesting:
http://www.faqs.org/docs/artu/minilanguageschapter.html
Jan
On 08/08/10 15:26, Lime, Steve D (DNR) wrote:
> Yes, I saw the OGR RFC thread, it prompted me to get off my butt...
> Can you provide some hints on 1? I'm not sure where to start. If there's a structure even closer
> to what is ultimately evaluated I'm all for it.
> Idea 2 is also a good idea, I'll have a look when I'm back from a short holiday.
> Steve
> ________________________________________
> From: mapserver-dev-bounces at lists.osgeo.org [mapserver-dev-bounces at lists.osgeo.org] On Behalf Of Frank Warmerdam [warmerdam at pobox.com]
> Sent: Saturday, August 07, 2010 8:47 AM
> To: Lime, Steve D (DNR)
> Cc: mapserver-dev at lists.osgeo.org
> Subject: Re: [mapserver-dev] RFC 59 Logical Expression Overhaul (preliminary    draft)
> On Fri, Aug 6, 2010 at 1:41 PM, Lime, Steve D (DNR)
> <Steve.Lime at state.mn.us>  wrote:
>> Hi all: I figure it's time to formally surface some work I've been doing relative to improving the function and extending the
>> use of the MapServer Bison/Yacc parser. For now I drafted the RFC on the wiki and will move to the dev. portion of the
>> website if necessary. I think this adds some pretty interesting functionality. Anyway, it's at:
>>   http://trac.osgeo.org/mapserver/wiki/RFC59-Draft
> Steve,
> This looks like a promising step.  Coincidentally, this is at the
> same time that I wrote an SQL parser using yacc/bison for OGR.
> A few thoughts.
> 1) Why not parse the expression once into an expression tree
> data structure and then just evaluate that each time instead of
> also having to run the parser each time?   I'm not sure what the
> speed advantage of this would be over doing the evaluation of
> the expression as part of parsing, but it *seems* like a more
> conventional approach.
> 2) You mention the use of globals to pass in stuff to the parser.
> I was able to use the parse-param and lex-param directives to
> Bison to have a 'context' data structure in to the parser and on
> to the lexer.  You can skim the .y file I came up with at:
> http://trac.osgeo.org/gdal/browser/sandbox/warmerdam/gdal-rfc28/gdal/ogr/swq_parser.y
> This was also a fully reentrant parsers so different threads could
> be parsing at the same time without serialization.  I'd be happy to
> help if you would like to investigate.
> I certainly agree that the old substitute and re-parse
> approach was a performance issue, so I'm pleased to
> see the direction you are moving.
> Best regards,
> I set the clouds in motion - turn up   | Frank Warmerdam, warmerdam at pobox.com
> light and sound - activate the windows | http://pobox.com/~warmerdam
> and watch the world go round - Rush    | Geospatial Programmer for Rent
> mapserver-dev mailing list
> http://lists.osgeo.org/mailman/listinfo/mapserver-dev
