[mapserver-dev] Tilecache WMS-C patch for 5.6.5
Yewondwossen Assefa yassefa at dmsolutions.ca
Tue Aug 10 10:28:26 EDT 2010
> You can read about it here:
> http://msdn.microsoft.com/en-us/library/bb259689.aspx
>> one question that comes in mind is there for you  a need to store
>> tiles using the VE structure or are you looking mainly to be able to
>> parse/respond VE type urls that use a quadtree value?
> Hmmm, that is a good question. I think the requirement is to be able
> to request tiles based on the quadtree value. So are you suggesting
> that we might be able to easily map the quadtree to the existing tile
> naming and storage mechanism? If so that might greatly reduce the code
> needed to implement support for VE quadtree requests.
I believe it should be possible to do the conversion. I have added few
notes in trac [1] on this . Thanks for adding the bug.
best regards,
[1]: http://trac.osgeo.org/mapserver/ticket/3513
Assefa Yewondwossen
Software Analyst
Email: yassefa at dmsolutions.ca
http://www.dmsolutions.ca/
Phone: (613) 565-5056 (ext 14)
Fax:   (613) 565-0925
