[mapserver-dev] Tilecache WMS-C patch for 5.6.5
Stephen Woodbridge woodbri at swoodbridge.com
Tue Aug 10 11:10:45 EDT 2010
Yewondwossen Assefa wrote:
>> You can read about it here:
>> http://msdn.microsoft.com/en-us/library/bb259689.aspx
>>> one question that comes in mind is there for you  a need to store
>>> tiles using the VE structure or are you looking mainly to be able to
>>> parse/respond VE type urls that use a quadtree value?
>> Hmmm, that is a good question. I think the requirement is to be able
>> to request tiles based on the quadtree value. So are you suggesting
>> that we might be able to easily map the quadtree to the existing tile
>> naming and storage mechanism? If so that might greatly reduce the code
>> needed to implement support for VE quadtree requests.
> I believe it should be possible to do the conversion. I have added few
> notes in trac [1] on this . Thanks for adding the bug.
> best regards,
> [1]: http://trac.osgeo.org/mapserver/ticket/3513
Thanks, I'm looking at adding that now and if I can get it working, I'll
update the patch and the ticket. This seems to much more straight
forward than my original thoughts, but hey that is why I let you guys do
the development and I just hack away at stuff :-)
-Steve W
