[mapserver-dev] RFC 59 Logical Expression Overhaul (preliminary draft)
Lime, Steve D (DNR) Steve.Lime at state.mn.us
Mon Aug 16 14:32:15 EDT 2010
The OGC filter specs allow (or require?) for setting an SRS in certain parts of a filter. So what I was referring to is how to support that. As it sits now I'd just suggest allowing a syntax like fromText(WKT, EPSG code) or something along those lines...
Steve
-----Original Message-----
From: mapserver-dev-bounces at lists.osgeo.org [mailto:mapserver-dev-bounces at lists.osgeo.org] On Behalf Of Jeff McKenna
Sent: Monday, August 09, 2010 2:37 PM
To: mapserver-dev at lists.osgeo.org
Subject: Re: [mapserver-dev] RFC 59 Logical Expression Overhaul (preliminary draft)
Steve,
One more question: how do projections affect this proposal?  (from RFC:
"how to handle projections?")   Do you mean how to parse the PROJECTION
object string?  I'm just curious about this.
-jeff
Lime, Steve D (DNR) wrote:
> Hi all: I figure it's time to formally surface some work I've been doing relative to improving the function and extending the
> use of the MapServer Bison/Yacc parser. For now I drafted the RFC on the wiki and will move to the dev. portion of the
> website if necessary. I think this adds some pretty interesting functionality. Anyway, it's at:
>   http://trac.osgeo.org/mapserver/wiki/RFC59-Draft
> and the sandbox implementation:
>   http://svn.osgeo.org/mapserver/sandbox/sdlime/common-expressions/mapserver
mapserver-dev mailing list
http://lists.osgeo.org/mailman/listinfo/mapserver-dev
