[mapserver-dev] mapscript & Java: error using mapscript DLL
maik imap at maik.schuerer.name
Wed Aug 25 11:39:33 EDT 2010
I try to run a very simple Java app:
mapObj map = new mapObj(filename);
where 'filename' points to my .MAP file
when I try to run I get:
mapscript.dll: Operating system fail to run %1
(original message is in German, but it should be in English something like
taht above)
Has anyone seen this message before and what could be the reason for that?
Thanks in advance
Maik
View this message in context: http://osgeo-org.1803224.n2.nabble.com/mapscript-Java-error-using-mapscript-DLL-tp5461851p5461851.html
Sent from the Mapserver - Dev mailing list archive at Nabble.com.
