[mapserver-dev] RE: [mapserver-users] Pan Mapserver C# asp.net
vivek.srivastawa at gmail.com
Tue Dec 7 04:37:08 EST 2010
Hi All,
I am stuck in one position, hope I will get solution from here.
I am calling Map server layer with help of Sharpmap WMS client, I have
created two layers, one is of Shrapmap layers and second one is of Map
server layer, I am using below Map file to accomplish this
MAP
NAME GMAP_DEMO
STATUS ON
SIZE 400 300
SYMBOLSET ../etc/symbols.txt
SHAPEPATH "../data"
IMAGECOLOR 255 0 0
FONTSET ../etc/fonts.txt
UNITS DD
EXTENT -180 -90 180 90 # Geographic
CONFIG "PROJ_LIB" "C:/ms4w/apps/gmap/proj/nad/epsg"
TRANSPARENT off
# Start of web interface definition
WEB
# On Windows systems, /tmp and /tmp/ms_tmp/ should be created at the root
# of the drive where the .MAP file resides.
IMAGEPATH "C:/ms4w/tmp/ms_tmp/"
IMAGEURL "/ms_tmp/"
METADATA
"wms_srs" "EPSG:4326"
END
END
# Start of layer definitions
LAYER
PROJECTION
"proj=latlong"
"ellps=WGS84"
END
NAME "world_poly"
DATA 'C:/ms4w/apps/gmap/shapefile/world_adm0.shp'
STATUS ON
TYPE POLYGON
CLASS
NAME 'The World'
STYLE
OUTLINECOLOR 0 0 0
END
END
END # layer
END # Map File
and I am calling this above map by my WMS client here is my WMS clint
string wmsUrl =
"http://localhost/cgi-bin/mapserv.exe?map=/ms4w/apps/gmap/htdocs/gmap_modified.map";
WmsLayer layWms = new WmsLayer("GMAP_DEMO", wmsUrl);
layWms.AddLayer("world_poly");
layWms.SetImageFormat(layWms.OutputFormats[1]);
//Map Server Transparancy
layWms.Transparancy = false;
layWms.SetImageFormat("image/png");
layWms.ContinueOnError = false;
layWms.BgColor = System.Drawing.Color.Red;
layWms.Enabled = true;
//Set timeout to 5 seconds
layWms.TimeOut = 5000;
//Map Server Projection ID
layWms.SRID = 4326;
map.Layers.Add(layWms);
The problem is this not showing any map, only blank screen is coming.
Please guide me to do this.
Thanks,
Vivek
View this message in context: http://osgeo-org.1803224.n2.nabble.com/RE-mapserver-users-Pan-Mapserver-C-asp-net-tp1974256p5810964.html
Sent from the Mapserver - Dev mailing list archive at Nabble.com.
