[mapserver-dev] Sharpmap WMS Client and calling Map layer is not
worKING
Vivek Srivastawa
vivek.srivastawa at gmail.com
Thu Dec 9 14:33:58 EST 2010
> Hi All,
> I am stuck in one position, hope I will get solution from here.
> I am calling Map server layer with help of Sharpmap WMS client, I have
> created two layers, one is of Shrapmap layers and second one is of Map
> server layer, I am using below Map file to accomplish this
> MAP
> NAME GMAP_DEMO
> STATUS ON
> SIZE 400 300
> SYMBOLSET ../etc/symbols.txt
> SHAPEPATH "../data"
> IMAGECOLOR 255 0 0
> FONTSET ../etc/fonts.txt
> UNITS DD
> EXTENT -180 -90 180 90 # Geographic
> CONFIG "PROJ_LIB" "C:/ms4w/apps/gmap/proj/nad/epsg"
> TRANSPARENT off
> # Start of web interface definition
> WEB
> # On Windows systems, /tmp and /tmp/ms_tmp/ should be created at the root
> # of the drive where the .MAP file resides.
> IMAGEPATH "C:/ms4w/tmp/ms_tmp/"
> IMAGEURL "/ms_tmp/"
> METADATA
> "wms_srs" "EPSG:4326"
> END
> END
> # Start of layer definitions
> LAYER
> PROJECTION
> "proj=latlong"
> "ellps=WGS84"
> END
> NAME "world_poly"
> DATA 'C:/ms4w/apps/gmap/shapefile/world_adm0.shp'
> STATUS ON
> TYPE POLYGON
> CLASS
> NAME 'The World'
> STYLE
> OUTLINECOLOR 0 0 0
> END
> END
> END # layer
> END # Map File
> and I am calling this above map by my WMS client here is my WMS clint
> string wmsUrl =
> http://localhost/cgi-bin/mapserv.exe?map=/ms4w/apps/gmap/htdocs/gmap_modified.map
> WmsLayer layWms = new WmsLayer("GMAP_DEMO", wmsUrl);
> layWms.AddLayer("world_poly");
> layWms.SetImageFormat(layWms.OutputFormats[1]);
> //Map Server Transparancy
> layWms.Transparancy = false;
> layWms.SetImageFormat("image/png");
> layWms.ContinueOnError = false;
> layWms.BgColor = System.Drawing.Color.Red;
> layWms.Enabled = true;
> //Set timeout to 5 seconds
> layWms.TimeOut = 5000;
> //Map Server Projection ID
> layWms.SRID = 4326;
> map.Layers.Add(layWms);
> The problem is this not showing any map, only blank screen is coming.
> Please guide me to do this.
> Thanks,
> Vivek
URL: http://lists.osgeo.org/pipermail/mapserver-dev/attachments/20101210/ac0adb4d/attachment.html
