[mapserver-dev] Large number of failed tests in autotest suite after merge of mapserver6 sandbox (rendering api) into trunk
Even Rouault even.rouault at mines-paris.org
Sat Dec 18 09:12:16 EST 2010
I've observed the following results in msautotest/wxs with latest trunk
(r10806):
18 tested skipped
134 tests succeeded
114 tests failed
I see similar pattern on Tamas daily builds ( see
http://vbkto.dyndns.org:1280/sdk/build-output/vc7-20101218-4-18-59-67-vc7-
dev.txt for example )
I've bissected it to be due to r10743 :
r10742 :
18 tested skipped
227 tests succeeded
21 tests failed
r10743 :
18 tested skipped
146 tests succeeded
102 tests failed
Best regards,
Even
