[mapserver-dev] Re: Large number of failed tests in autotest suite
after merge of mapserver6 sandbox (rendering api) into trunk
thomas bonfort
thomas.bonfort at gmail.com
Mon Dec 20 03:36:58 EST 2010
Even,
most of the changes are related to a switch of rendering engine for
the png24 imagetype. There are a few other test cases that reveal a
true problem that I'll have a look into.
regards,
thomas
On Sat, Dec 18, 2010 at 15:12, Even Rouault
<even.rouault at mines-paris.org> wrote:
> Hi,
> I've observed the following results in msautotest/wxs with latest trunk
> (r10806):
> 18 tested skipped
> 134 tests succeeded
> 114 tests failed
> I see similar pattern on Tamas daily builds ( see
> http://vbkto.dyndns.org:1280/sdk/build-output/vc7-20101218-4-18-59-67-vc7-
> dev.txt for example )
> I've bissected it to be due to r10743 :
> r10742 :
> 18 tested skipped
> 227 tests succeeded
> 21 tests failed
> r10743 :
> 18 tested skipped
> 146 tests succeeded
> 102 tests failed
> Best regards,
> Even
