[mapserver-dev] Global "Substitution" RFC
Dan Little danlittle at yahoo.com
Wed Feb 3 13:04:18 EST 2010
I would anticipate this would work in concert with all other substitution mechanisms and so the string parsing will require some serious consideration.
This RFC is a little more adventurous than the database-variable binding solution I purposed earlier.  I'm still working on doing the research for how the parsing would work, my hope was to spend some code-sprint time working on the exploratory bits if there was some interest.
I'm still working on acclimating to the formal processes of RFC submission and has presumed that I needed to purpose something before it was given an accepted number.
----- Original Message ----
> From: Frank Warmerdam <warmerdam at pobox.com>
> To: Dan Little <danlittle at yahoo.com>
> Cc: Mapserver Dev <mapserver-dev at lists.osgeo.org>
> Sent: Wed, February 3, 2010 11:59:25 AM
> Subject: Re: [mapserver-dev] Global "Substitution" RFC
> Dan Little wrote:
> > Of course, this time I just wrote an RFC and this probably deserves some
> > discussion.  My general idea/hope is to eliminate some of the need for
> > people to need templating systems for complex mapfiles.   Or at least make
> > the management of extensive mapfiles a little easier.
> Duck,
> I'm interested in how the substitution mechanism you propose relates to
> other substitution mechanisms already in place in MapServer.  I gather there
> is a way of passing extra values in the url that can be substituted somehow.
> I wonder if there would be some way of tieing into the same syntax.
> Were you planning to implement the RFC yourself?  Have you done experiments
> to see how hard it would be to parse the SETTING[''] values the way you want?
> If you want to proceed, you should assign an RFC number and get the RFC into
> the normal RFC repository.
> Best regards,
> I set the clouds in motion - turn up   | Frank Warmerdam, warmerdam at pobox.com
> light and sound - activate the windows | http://pobox.com/~warmerdam
> and watch the world go round - Rush    | Geospatial Programmer for Rent
