[mapserver-dev] RE: [mapserver-users] colorramp and datarangeonthe fly?
Bob Basques Bob.Basques at ci.stpaul.mn.us
Thu Feb 4 14:04:55 EST 2010
Steve,
I thought about the template process, and this would likely work with
the first pass, where MapServer does a basic or simple version of a set
of settings after looking at the datasource,
Using the preconceived STAT string seems limiting as far as user
interaction.  If all the setting from the user or site config are
already known, then that would work.  I was looking at how to augment or
adjust a specific ramp value within a set of them, but you have that
possibility in your example as well.
I'm interested for the most part in how to capture user input for the
ramp classing.
bobb
>>> "Lime, Steve D (DNR)" <Steve.Lime at state.mn.us> wrote:
You’re always mixing things up aren’t you…
I don’t think you need a  special mode. This strikes me as just another
special form of template output based on a query.  Presently you can get
layer level  query data (e.g. number of results) and of course spatial
and non-spatial attributes for each feature. What’s needed here is the
mechanism to gather layer stats (and a definition of what those are) in
either draw or query context and then a means of using or presenting
them.  Imaging in a new “stats” tag within a result set like so (within
a resultset tag):
    [stats item=”foo” format=”$stddev,$min,$max”]
You could use that to populate XML, JSON or just plain HTML output for
use on the client. This tag would draw from a populated layerStatsObj
which might consist of an array or hash of itemStatsObj’s…  You could
populate those objects on-the-fly or perhaps even from a file. Would
probably need a new STATS … END block within a layer to drive this. Just
thinking out loud.
Steve
Bob Basques [mailto:Bob.Basques at ci.stpaul.mn.us]
Sent: Thursday, February 04, 2010 8:19 AM
To: Lime, Steve D (DNR); Stephen Woodbridge; Jan Hartmann
Cc: MapServer Dev Mailing List; mapserver-users at lists.osgeo.org
Subject: RE: [mapserver-dev] RE: [mapserver-users] colorramp and
datarangeon the fly?
All,
Just to mix it up a little, what about doing a half and half approach.
MapServer could generate something simpler (the data basics from a data
read on the fly, and return a simple ramping config file, which could be
used to pass back as a  file for the custom aspects.
Just having these two options would open up some doors, MapServer
returning a simple ramp structure as a file, could be used in a User
interface to do more complicated theming for example.  Once the basic
data limits are known, the ramping divisions are much easier to decide
on.
Could this work as a compiled in module for those that need/want it
instead of always in? or would it make more sense to build in, ??
Something similar to a mode=legend sort of thing, like mode=ramp_txt ??
bobb
At one point I toyed with the idea of supporting a .stats file for a
layer and supplying a routine (command-line) that would populate it. The
file would contain data like you're talking about. Doesn't help with the
on-the-fly needs Bart was articulating.
Steve
-----Original Message-----
[mailto:mapserver-users-bounces at lists.osgeo.org] On Behalf Of Stephen
Woodbridge
Sent: Wednesday, February 03, 2010 10:39 AM
To: Jan Hartmann
Cc: Lime, Steve D (DNR); MapServer Dev Mailing List;
Subject: Re: [mapserver-dev] RE: [mapserver-users] colorramp and
datarange on the fly?
Right, I think there are two use cases:
1) data exploration   - can be slower but needs flexibility
2) production serving - needs to be fast, and probably limits
flexibility to some predefined models
I think that there is also another angle to this, which is how the
summary data is computed for example:
1) min/max/average/std
2) statistical analysis
3) binning into some number of classes
4) removing outli
ers so the results are not skewedIf the data is in a database, then you can add all the analysis, slicing
and dicing to the database and the rendering to mapserver.
So, I think that it would be nice to be able to read some "metadata"
about a layer and then use that for building the display using something
like colorramp and datarange. We might want to look at ways that we
could establish in mapserver for fetching the "metadata" about a layer.
For example:
1) define the "metadata" in the METADATA object
2) define a .met file for a shapefile or tileindex that contained the
"metadata" for that layer
3) define a separate SQL query that could be used to fetch the
"metadata" for the layer
4) something similar for other layer providers.
5) scan the data in two passes to compute some simple "metadata"
Thoughts?
-Steve W
Jan Hartmann wrote:
> If you allow two passes, you can have all sorts of summarized values
in
> the template, to be used in the second pass, like Bart's actual extent
> used for coloring. Doesn't look to difficult to implement to me, as
long
> as the two passes only get called when really necessary. I'm not sure
if
> performance is an issue for MapServer itself: if you really want high
> performance, you should use the underlying format or database
directly.
> Jan
> On 3-2-2010 17:02, Lime, Steve D (DNR) wrote:
>> How big a change would depend on the implementation. The brute force
>> approach where you simply loop through features once to compute
ranges
>> and then again to draw would be probably pretty straight forward and
>> driver independent. Wouldn't be fast (but would be simple).
Complexity
>> would be added as you try and boost performance by:
>>    - allowing drivers to compute stats in their own way (e.g. add to
>> the layer API something like msLayerGetStats(...))
>>    - caching geometries from a first pass through the shapes for the
>> second
>> Steve
>> BTW The color ramp support needs to be cleaned up first. I think we
>> scared the originator of that code away when an RFC was originally
put
>> together.
>> From: mapserver-users-bounces at lists.osgeo.org
>> [mailto:mapserver-users-bounces at lists.osgeo.org] On Behalf Of Bart
van
>> den Eijnden
>> Sent: Wednesday, February 03, 2010 5:12 AM
>> To: mapserver-users at lists.osgeo.org
>> Subject: [mapserver-users] colorramp and datarange on the fly?
>> Hi list,
>> is it possible to have a colorramp in Mapserver based on the min and
>> max value in the current extent?
>> So instead of predefining the min and max in DATARANGE, have
Mapserver
>> use the min and max value of the dataset in the current extent?
>> If not, would it be an easy change or a very complex one?
>> Best regards,
>> Bart_______________________________________________
>> mapserver-users mailing list
>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
>> mapserver-dev mailing list
>> mapserver-dev at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapserver-dev
URL: http://lists.osgeo.org/pipermail/mapserver-dev/attachments/20100204/64a44bcb/attachment.html
