[mapserver-dev] RE: [mapserver-users] colorramp and datarangeon
the fly?
Jan Hartmann
j.l.h.hartmann at uva.nl
Thu Feb 11 05:27:14 EST 2010
Some overlap here (from PostGis-users) ?
On 10-2-2010 23:46, Paul Ramsey wrote:
> Someday it would be nice to formalize a few common BI routines in PostGIS:
> http://opengeo.org/products/coredevelopment/postgis/bi-utilities/
On 9-2-2010 19:32, Lime, Steve D (DNR) wrote:
> I don't want to see this die. Perhaps we could take thread and either rework RFC 6 (http://mapserver.org/development/rfc/ms-rfc-6.html) which has to do with color ramping or create a new one to supplant it. Any takers?
> Steve
> -----Original Message-----
> From: Stephen Woodbridge [mailto:woodbri at swoodbridge.com]
> Sent: Thursday, February 04, 2010 12:39 PM
> To: Lime, Steve D (DNR)
> Cc: Bob Basques; Jan Hartmann; MapServer Dev Mailing List; mapserver-users at lists.osgeo.org
> Subject: Re: [mapserver-dev] RE: [mapserver-users] colorramp and datarangeon the fly?
> To build on what Steve is saying it might help to think of features in
> mapserver as requiring two separate components:
> 1) the algorithm
> 2) the presentation
> Obviously you can not present something that you do not have. the
> algorithm is how you generate stuff. Once we have stuff we need to
> present it via the multitude of rendering modules and interfaces, like
> the CGI interface or template interface, etc and rendered as text, json,
> xml, etc.
> I think adding a STATS object might be a good way to add pluggable
> algorithms and filters into the layer.
> A year plus ago, I did some research into thematic cartography and the
> math and statistics involved in that.
> Here are some of the data classification methods we might want to support:
> 1) equal intervals
> 2) quantiles (quartiles are n=4 quantiles)
> 3) mean-standard deviation
> 4) maximum breaks
> 5) natural breaks
> 6) optimal
> You can probably find more on these on wikipedia if you want the math
> behind them.
> In addition to the above for choropleths we might want to consider
> bivariant or multivariant analysis.
> And there is also a need to apply filters to the data like:
> 1) eliminate outliers
> 2) numerous smoothing algorithms that might be appropriate
> - triangularization
> - inverse distance
> - kriging
> - various interpolation routines that solve various issues with the data
> 3) probably others
> You might look on Amazon used books for some reference material on
> thematic mapping. I got the following:
> Introduction to Thematic Cartography, by Judith Tyner
> Thematic Cartography and Visualization, by Terry Slocum
> Thematic Cartography and Geographic Visualization, by Slocum, McMaster,
> Kessler and Howard
> These are all excellent and there are a lot of others.
> I think the point here is that there is a lot of research that has gone
> into this field and if we want to build tools that will allow mapserver
> to work effectively in this area, and I DO think we should do this, then
> we need to understand the scope of what needs to be done even if it is
> not all done at once and we need to build a pluggable interface that
> allows us to easily add stats analysis and apply statistical filters as
> the need arises. I think for the most part what Steve L has described
> will meet (I guessing) 80-90% of the requirements that might reasonably
> thrown at us and the others we can most likely say are too specialized
> or out of scope.
> I will also note that for the most part it can be argued that mapserver
> should NOT do the analysis, that that is the realm of other tools, but
> given that the analysis has been preformed that mapserver needs to
> support rendering it. Some of the analysis mentioned above it
> non-trivial to do on the fly. It is not clear to me where we draw a line
> in the sand and justify yes this in mapserver, no, that is not in mapserver.
> Ok, sorry this probably way more than any of you want to know :)
> -Steve W
>> You're always mixing things up aren't you...
>> I don't think you need a special mode. This strikes me as just another
>> special form of template output based on a query. Presently you can get
>> layer level query data (e.g. number of results) and of course spatial
>> and non-spatial attributes for each feature. What's needed here is the
>> mechanism to gather layer stats (and a definition of what those are) in
>> either draw or query context and then a means of using or presenting
>> them. Imaging in a new "stats" tag within a result set like so (within
>> a resultset tag):
>> [stats item="foo" format="$stddev,$min,$max"]
>> You could use that to populate XML, JSON or just plain HTML output for
>> use on the client. This tag would draw from a populated layerStatsObj
>> which might consist of an array or hash of itemStatsObj's... You could
>> populate those objects on-the-fly or perhaps even from a file. Would
>> probably need a new STATS ... END block within a layer to drive this. Just
>> thinking out loud.
>> Steve
>> *From:* Bob Basques [mailto:Bob.Basques at ci.stpaul.mn.us]
>> *Sent:* Thursday, February 04, 2010 8:19 AM
>> *To:* Lime, Steve D (DNR); Stephen Woodbridge; Jan Hartmann
>> *Cc:* MapServer Dev Mailing List; mapserver-users at lists.osgeo.org
>> *Subject:* RE: [mapserver-dev] RE: [mapserver-users] colorramp and
>> All,
>> Just to mix it up a little, what about doing a half and half approach.
>> MapServer could generate something simpler (the data basics from a data
>> read on the fly, and return a simple ramping config file, which could be
>> used to pass back as a file for the custom aspects.
>> Just having these two options would open up some doors, MapServer
>> returning a simple ramp structure as a file, could be used in a User
>> interface to do more complicated theming for example. Once the basic
>> data limits are known, the ramping divisions are much easier to decide on.
>> Could this work as a compiled in module for those that need/want it
>> instead of always in? or would it make more sense to build in, ??
>> Something similar to a mode=legend sort of thing, like mode=ramp_txt ??
>> bobb
>> >>> "Lime, Steve D (DNR)"<Steve.Lime at state.mn.us> wrote:
>> At one point I toyed with the idea of supporting a .stats file for a
>> layer and supplying a routine (command-line) that would populate it. The
>> file would contain data like you're talking about. Doesn't help with the
>> on-the-fly needs Bart was articulating.
>> Steve
>> From: mapserver-users-bounces at lists.osgeo.org
>> [mailto:mapserver-users-bounces at lists.osgeo.org] On Behalf Of Stephen
>> Woodbridge
>> Sent: Wednesday, February 03, 2010 10:39 AM
>> To: Jan Hartmann
>> Cc: Lime, Steve D (DNR); MapServer Dev Mailing List;
>> datarange on the fly?
>> Right, I think there are two use cases:
>> 1) data exploration - can be slower but needs flexibility
>> 2) production serving - needs to be fast, and probably limits
>> flexibility to some predefined models
>> I think that there is also another angle to this, which is how the
>> summary data is computed for example:
>> 1) min/max/average/std
>> 2) statistical analysis
>> 3) binning into some number of classes
>> 4) removing outliers so the results are not skewed by them
>> 5) etc
>> There are a lot of ways the people might need to summarize they data.
>> If the data is in a database, then you can add all the analysis, slicing
>> and dicing to the database and the rendering to mapserver.
>> So, I think that it would be nice to be able to read some "metadata"
>> about a layer and then use that for building the display using something
>> like colorramp and datarange. We might want to look at ways that we
>> could establish in mapserver for fetching the "metadata" about a layer.
>> For example:
>> 1) define the "metadata" in the METADATA object
>> 2) define a .met file for a shapefile or tileindex that contained the
>> "metadata" for that layer
>> 3) define a separate SQL query that could be used to fetch the
>> "metadata" for the layer
>> 4) something similar for other layer providers.
>> 5) scan the data in two passes to compute some simple "metadata"
>> Thoughts?
>> -Steve W
>> Jan Hartmann wrote:
>> > If you allow two passes, you can have all sorts of summarized values in
>> > the template, to be used in the second pass, like Bart's actual extent
>> > used for coloring. Doesn't look to difficult to implement to me, as long
>> > as the two passes only get called when really necessary. I'm not sure if
>> > performance is an issue for MapServer itself: if you really want high
>> > performance, you should use the underlying format or database directly.
>> > Jan
>> > On 3-2-2010 17:02, Lime, Steve D (DNR) wrote:
>> >> How big a change would depend on the implementation. The brute force
>> >> approach where you simply loop through features once to compute ranges
>> >> and then again to draw would be probably pretty straight forward and
>> >> driver independent. Wouldn't be fast (but would be simple). Complexity
>> >> would be added as you try and boost performance by:
>> >> - allowing drivers to compute stats in their own way (e.g. add to
>> >> the layer API something like msLayerGetStats(...))
>> >> - caching geometries from a first pass through the shapes for the
>> >> second
>> >> Steve
>> >> BTW The color ramp support needs to be cleaned up first. I think we
>> >> scared the originator of that code away when an RFC was originally put
>> >> together.
>> >> [mailto:mapserver-users-bounces at lists.osgeo.org] On Behalf Of Bart van
>> >> den Eijnden
>> >> Sent: Wednesday, February 03, 2010 5:12 AM
>> >> To: mapserver-users at lists.osgeo.org
>> >> Subject: [mapserver-users] colorramp and datarange on the fly?
>> >> Hi list,
>> >> is it possible to have a colorramp in Mapserver based on the min and
>> >> max value in the current extent?
>> >> So instead of predefining the min and max in DATARANGE, have Mapserver
>> >> use the min and max value of the dataset in the current extent?
>> >> If not, would it be an easy change or a very complex one?
>> >> Best regards,
>> >> Bart_______________________________________________
>> >> mapserver-users mailing list
>> >> http://lists.osgeo.org/mailman/listinfo/mapserver-users
>> >> mapserver-dev mailing list
>> >> mapserver-dev at lists.osgeo.org
>> >> http://lists.osgeo.org/mailman/listinfo/mapserver-dev
