[mapserver-dev] configure in repository
Paul Ramsey
pramsey at cleverelephant.ca
Mon Feb 15 13:05:40 EST 2010
Is there an approved set of versions of autoconf, etc, to rebuild
configure? I admit, I checked in some changes to configure.in, but I
didn't have the stones to overwrite configure.
P.
On Mon, Feb 15, 2010 at 7:35 AM, Frank Warmerdam <warmerdam at pobox.com> wrote:
> strk wrote:
>> Hi all,
>> is it intentional for 'configure' script to be in
>> the repository ? I ask `cause I'm trying to fix
>> a linking problem (see ticket #3316) but found
>> the current configure.in not resulting in a correct
>> 'configure' after an 'autoconf' run.
>> The usual way to go is only having 'configure.in'
>> in the repository and providing an 'autogen.sh'
>> script checking compatibility of generator tools
>> and running them in the correct order...
> Strk,
> It is intentional. It ensures that folks without the exactly matching
> version of autoconf and related stuff that work properly for MapServer
> can still build from SVN.
> A curse on autogen.sh - leave my mapserver alone!
> Ahem, I mean, that's just my opinion.
> Best regards,
> I set the clouds in motion - turn up | Frank Warmerdam,
> light and sound - activate the windows | http://pobox.com/~warmerdam
> and watch the world go round - Rush | Geospatial Programmer for Rent
> mapserver-dev mailing list
> mapserver-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapserver-dev
