[mapserver-dev] Tile Mode Enhancements
Stephen Woodbridge woodbri at swoodbridge.com
Thu Feb 18 17:20:57 EST 2010
OK, Great! then I would go for it.
-Steve W
Paul Ramsey wrote:
> It doesn't relate. I reviewed Assefa's patch first to make sure I
> wasn't reinventing any wheels. This alteration doesn't do any caching,
> and supports the mode=tile only, for GMaps and Bing. It's a pretty
> small patch.
> P.
> On Thu, Feb 18, 2010 at 1:50 PM, Stephen Woodbridge
> <woodbri at swoodbridge.com> wrote:
>> Paul Ramsey wrote:
>>> In mode=tile, support for in-memory metatiling and rendering
>>> to/clipping from an expanded image buffer.
>>> Back when I put in tilemode, we discussed these enhancements as being
>>> pretty useful. And I've got a patch queued up to add them. Any
>>> concerns?
>>> http://trac.osgeo.org/mapserver/ticket/3323
>> Hi Paul,
>> How does this relate, overlap or not to the WMS-C support that Assefa has
>> implemented?
>> Basically he has a patch that implements WMS-C tilecache support in
>> mapserver and does metatile rendering and tile slicing and implements a
>> tilecache using mapserver.
>> I have installed the patch here and added support for the configure and the
>> Linux build environment. It works really nicely. I think there are a few
>> rough edges, but it was pretty easy to setup and plug into openlayers.
>> Assefa mentioned that he might be interested in working on this at the NY
>> Code sprint. I'm sorry I missed the IRC yesterday and will not be at the
>> code sprint. I think it might be a good idea if you two got together and
>> combined efforts.
>> Best regards,
>>  -Steve W
>> mapserver-dev mailing list
>> mapserver-dev at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapserver-dev
