[mapserver-dev] Tile Mode Enhancements
Paul Ramsey
pramsey at opengeo.org
Thu Feb 18 16:55:14 EST 2010
It doesn't relate. I reviewed Assefa's patch first to make sure I
wasn't reinventing any wheels. This alteration doesn't do any caching,
and supports the mode=tile only, for GMaps and Bing. It's a pretty
small patch.
P.
On Thu, Feb 18, 2010 at 1:50 PM, Stephen Woodbridge
<woodbri at swoodbridge.com> wrote:
> Paul Ramsey wrote:
>> In mode=tile, support for in-memory metatiling and rendering
>> to/clipping from an expanded image buffer.
>> Back when I put in tilemode, we discussed these enhancements as being
>> pretty useful. And I've got a patch queued up to add them. Any
>> concerns?
>> http://trac.osgeo.org/mapserver/ticket/3323
> Hi Paul,
> How does this relate, overlap or not to the WMS-C support that Assefa has
> implemented?
> Basically he has a patch that implements WMS-C tilecache support in
> mapserver and does metatile rendering and tile slicing and implements a
> tilecache using mapserver.
> I have installed the patch here and added support for the configure and the
> Linux build environment. It works really nicely. I think there are a few
> rough edges, but it was pretty easy to setup and plug into openlayers.
> Assefa mentioned that he might be interested in working on this at the NY
> Code sprint. I'm sorry I missed the IRC yesterday and will not be at the
> code sprint. I think it might be a good idea if you two got together and
> combined efforts.
> Best regards,
> -Steve W
> mapserver-dev mailing list
> mapserver-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapserver-dev
