[mapserver-dev] MS RFC 37: AUTO Projection Support
Perry Nacionales pnaciona at gmail.com
Sun Feb 21 13:11:26 EST 2010
+1
Looks good.
On Sun, Feb 21, 2010 at 11:46 AM, Howard Butler <hobu.inc at gmail.com> wrote:
> On Feb 21, 2010, at 11:32 AM, Frank Warmerdam wrote:
> > A few points:
> > 1) What will happen if PROJECTION AUTO is used for a layer type that does
> > not implement LayerGetAutoProjection?  I hope an error will be issued.
> yes.
> > 2) Are you proposing to do the implementation for shapefile, OGR, GDAL
> Raster,
> > ArcSDE and PostGIS?  I'd be happy to do it for GDAL Raster if you wish.
> I will do shapefile, SDE, PostGIS, and adapt the existing OGR/GDAL stuff.
>  Hopefully Jim can help with the Oracle driver
> > 3) I think it would have been worth nothing that OGR and raster already
> > supported AUTO though this wasn't widely used or known.  I don't
> anticipate
> > any compatability issues with changing to this approach.
> The PROJECTION block will now support AUTO as well as "AUTO", but other
> than that, unchanged.
> mapserver-dev mailing list
> mapserver-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapserver-dev
URL: http://lists.osgeo.org/pipermail/mapserver-dev/attachments/20100221/3c31aa0e/attachment.html
