[mapserver-dev] WorldMapping issue
Roger André
randre at gmail.com
Mon Feb 22 11:49:08 EST 2010
re: But maybe I'm missing something as I never used the "tile"
support in MS (does it exist ? does it handle labels nicely?)
Yes, it does exist, http://mapserver.org/output/tile_mode.html, and with the
upcoming addition of support for metatiling and edge buffering,
http://trac.osgeo.org/mapserver/ticket/3323, it appears that labels look
quite good.
Roger
On Mon, Feb 22, 2010 at 7:44 AM, strk <strk at keybit.net> wrote:
> On Mon, Feb 22, 2010 at 08:33:30AM -0500, Frank Warmerdam wrote:
> > I *suspect* the best way to handle it well would be for MapServer
> > to understand something special about the dateline, at least about
> > geographic coordinate systems, and to split dateline crossing
> > requests into two or more requests.
> > So the -360 to +360 case should be broken into 3 requests:
> > -360 to -180 which would be internally rendered as 0 to 180.
> > -180 to +180 which would be rendered as -180 to +180
> > +180 to +360 which would be rendered as -180 to 0.
> > Then the three results should be mosaiced back together.
> > Unfortunately this would require a fair amount of development
> > work.
> This would pretty much mimic what you can get with OL,
> so would present the same limits (handling of labels).
> > I do not thing it would be practical to recognize limits to
> > projected coordinate systems and to use such a technique
> > though similar wrapping issues can apply in projected
> > coordinate systems as well. For instance this is
> > fairly straight forward in mercator, but complicated in
> > many projections like the perspective view ones.
> I guess the "dateline" concept would be good enough.
> --strk;
> () Free GIS & Flash consultant/developer
> /\ http://foo.keybit.net/~strk/services.html<http://foo.keybit.net/%7Estrk/services.html>
> mapserver-dev mailing list
> mapserver-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapserver-dev
URL: http://lists.osgeo.org/pipermail/mapserver-dev/attachments/20100222/58d4d77e/attachment-0001.html
