[mapserver-dev] Possible bug found
Daniel Morissette
dmorissette at mapgears.com
Thu Jan 21 09:58:13 EST 2010
Not really a bug or undocumented feature, just the way we chose to
implement WMS.
If you do a GetCapabilities, you'll see a layer at the top level (which
corresponds to the overall map and uses the map name) and then all
individual mapfile layers are at the second level under that top-level
layer. As per WMS spec, referring to any layer by name in a GetMap
request will return that layer and all its children, so what Guillaume
experienced is consistent according too WMS spec.
WMS requires at least 2 levels <layer> of nesting in the Capabilities
(what we did, one global layer for the overall map, and then individual
layers underneath). The only thing we may be missing is a way to make
the top-level layer not-requestable by not setting a name on it.
I saw a comment from Assefa in a ticket a few days ago about adding that
option. I just don't have the ref with me at the moment.
Daniel
Lime, Steve D (DNR) wrote:
> Wow, that's a new one on me. Perhaps a ticket to either document it or remove it could be created.
> Steve
> ________________________________________
> From: mapserver-dev-bounces at lists.osgeo.org [mapserver-dev-bounces at lists.osgeo.org] On Behalf Of Dan Little [danlittle at yahoo.com]
> Sent: Thursday, January 21, 2010 8:03 AM
> To: MapServer Dev Mailing List
> Subject: Re: [mapserver-dev] Possible bug found
> If your map name is "selection" and you request "selection," MapServer believes you are requesting the entire map. This is an "undocumented feature."
> ----- Original Message ----
>> From: Guillaume Sueur <no-reply at neogeo-online.net>
>> To: MapServer Dev Mailing List <mapserver-dev at lists.osgeo.org>
>> Sent: Thu, January 21, 2010 5:08:34 AM
>> Subject: [mapserver-dev] Possible bug found
>> Hi,
>> I've faced a strange situation where all layers of a map (turned off by
>> default) were showing when requesting a specific layer in WMS.
>> layers are :
>> selection
>> departement
>> region
>> selection_label
>> when asking for selection layer, all others layer were showing. renaming
>> selection to something else and asking still for selection layer had the
>> same result, a full map.
>> The only clue I've found is that my map is named selection.Changing it
>> to whatever else solves the problem.
>> Is this conflict between map name and layer name a normal behaviour ?
>> Regards,
>> Guillaume
>> mapserver-dev mailing list
>> http://lists.osgeo.org/mailman/listinfo/mapserver-dev
Daniel Morissette
http://www.mapgears.com/
