[mapserver-dev] WMS and cookies
    Yewondwossen Assefa
    yassefa at dmsolutions.ca
    Wed Jan 27 09:29:45 EST 2010
Bart van den Eijnden wrote:
> Hi,
> see below from wms-dev, Mapserver in WMS mode will give cookies
> preference over URL parameters. I've always found this unwanted, so I
> have my own custom patch for it, which I now want to get rid off :-)
> Would it be worthwhile changing this in Mapserver? CGI mode can remain
> the same.
> Objections? Thoughts?
Bart,
 I agree with you that that overwriting url parameters by cookies  is an
unwanted behavior  for both OGC and CGI. Maybe It should be the other
way around; It would change the current behavior but  I could not find
in MapServer  docs explaining the current behavior so I tend to believe
that It is not used consciously by a lot of users.
What does your patch do?
regards,
> Best regards,
> Bart
> Begin forwarded message:
>> *From: *Raj Singh <raj at rajsingh.org <mailto:raj at rajsingh.org>>
>> *Date: *January 26, 2010 3:38:12 PM GMT+01:00
>> *To: *bartvde at osgis.nl <mailto:bartvde at osgis.nl>
>> *Cc: *wms-dev at lists.eogeo.org <mailto:wms-dev at lists.eogeo.org>
>> *Subject: **Re: [wms-dev] WMS and cookies*
>> The spec doesn't say anything about cookies, so they should be
>> ignored by a WMS implementation.
>> Raj
>> On Jan 26, at 3:13 AM, bartvde at osgis.nl <mailto:bartvde at osgis.nl> wrote:
>>> Hi list,
>>> what is the policy of WMS wrt cookies? I could not find anything in
>>> the spec.
>>> If a WMS receives a cookie param named LAYERS for instance, does it take
>>> precedence over the url parameter? Or should a WMS ignore cookies?
>>> Best regards,
>>> Bart
>>> wms-dev mailing list
>>> http://lists.eogeo.org/mailman/listinfo/wms-dev
> mapserver-dev mailing list
> mapserver-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapserver-dev
Assefa Yewondwossen
Software Analyst
Email: assefa at dmsolutions.ca
http://www.dmsolutions.ca/
Phone: (613) 565-5056 (ext 14)
Fax:   (613) 565-0925
