[mapserver-dev] WMS GetFeatureInfo not working on Oracle in trunk
Bart van den Eijnden (OSGIS) bartvde at osgis.nl
Tue Jul 27 02:38:07 EDT 2010
Hi list,
trying out trunk (r10376), but WMS GetFeatureInfo is crashing on Oracle
Spatial layers (output is truncated). Debug info is:
[bart at nwr-iovl-geo002 trunk]$ ./mapserv-core
"QUERY_STRING=map=/data/OGC_UMN_services/test_vector.map&LAYERS=ORA_POLY&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetFeatureInfo&STYLES=&EXCEPTIONS=application%2Fvnd.ogc.se_xml&SRS=EPSG%3A28992&BBOX=122757.714116%2C434907.834101%2C204041.825055%2C469124.423963&X=452&Y=129&INFO_FORMAT=application%2Fvnd.ogc.gml&QUERY_LAYERS=ORA_POLY&FEATURE_COUNT=1&WIDTH=1031&HEIGHT=434"
[Tue Jul 27 08:34:28 2010].343306 msOracleSpatialLayerOpen called with:
SHAPE FROM (SELECT OBJECTID, HECTARES, ZONENR, NULZONES, AREA, PERIMETER,
SHAPE FROM GRENZEN.OV_ZONERING) USING UNIQUE OBJECTID (Layer pointer
0x8630840)
[Tue Jul 27 08:34:28 2010].464171 msOracleSpatialLayerOpen. Shared
connection not available. Creating one.
[Tue Jul 27 08:34:28 2010].464892
msConnPoolRegister(ORA_POLY,RWS_LEZEN/RWS_LEZEN at geodatabase.ad.rws.nl:1521/PGPR.rws.nl,0x87722b0)
[Tue Jul 27 08:34:28 2010].478015 msOracleSpatialLayerFreeItemInfo was
called.
[Tue Jul 27 08:34:28 2010].478734 msOracleSpatialLayerFreeItemInfo was
called.
[Tue Jul 27 08:34:28 2010].479369 msOracleSpatialLayerGetItems was called.
[Tue Jul 27 08:34:28 2010].483218 msOracleSpatialLayerInitItemInfo was
called.
[Tue Jul 27 08:34:28 2010].484048 msOracleSpatialLayerInitItemInfo was
called.
[Tue Jul 27 08:34:28 2010].484806 msOracleSpatialLayerWhichShapes was called.
[Tue Jul 27 08:34:28 2010].485589 msOracleSpatialLayerWhichShapes. Using
this Sql to retrieve the data: SELECT OBJECTID, HECTARES, ZONENR,
NULZONES, AREA, PERIMETER, rownum, SHAPE FROM (SELECT OBJECTID, HECTARES,
ZONENR, NULZONES, AREA, PERIMETER, SHAPE FROM GRENZEN.OV_ZONERING) WHERE
SDO_FILTER( SHAPE, MDSYS.SDO_GEOMETRY(2003, :srid,
NULL,MDSYS.SDO_ELEM_INFO_ARRAY(1,1003,3),:ordinates ),'querytype=window')
= 'TRUE'
[Tue Jul 27 08:34:28 2010].490377 msOracleSpatialLayerWhichShapes. Bind
values: srid:-1   minx:158432.845251   miny:458914.635053
maxx:158432.845251   maxy:458914.635053
[Tue Jul 27 08:34:28 2010].491033 msOracleSpatialLayerWhichShapes getting
ordinate definition.
[Tue Jul 27 08:34:28 2010].494052 msOracleSpatialLayerWhichShapes
converting to OCIColl.
[Tue Jul 27 08:34:28 2010].495951 msOracleSpatialLayerWhichShapes bind by
name and object.
[Tue Jul 27 08:34:28 2010].496910 msOracleSpatialLayerWhichShapes name and
object now bound.
[Tue Jul 27 08:34:28 2010].521059 msOracleSpatialLayerNextShape on layer
0x8630840, row_num: 0
[Tue Jul 27 08:34:28 2010].522846 msOracleSpatialLayerNextShape on layer
0x8630840, row_num: 1
[Tue Jul 27 08:34:28 2010].524501 msOracleSpatialLayerNextShape on layer
0x8630840, Fetched 0 more rows (1 total)
Content-type: application/vnd.ogc.gml
<?xml version="1.0" encoding="ISO-8859-1"?>
<msGMLOutput
         xmlns:gml="http://www.opengis.net/gml"
         xmlns:xlink="http://www.w3.org/1999/xlink"
         xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance">
        <ORA_POLY_layer>
[Tue Jul 27 08:34:28 2010].528379 msOracleSpatialLayerResultGetShape():
OracleSpatial error. msOracleSpatialLayerResultGetShape record out of
range
[Tue Jul 27 08:34:28 2010].529060 msOracleSpatialLayerClose was called.
Layer: 0x8630840, Layer name: ORA_POLY. Layer connection:
[Tue Jul 27 08:34:28 2010].530614 msOracleSpatialLayerClose. Cleaning
layerinfo handlers.
[Tue Jul 27 08:34:28 2010].531716 msOracleSpatialLayerClose. Release the
Oracle Pool.
[Tue Jul 27 08:34:28 2010].532320
msConnPoolRelease(ORA_POLY,RWS_LEZEN/xxxx at geodatabase.ad.rws.nl:1521/PGPR.rws.nl,0x87722b0)
[Tue Jul 27 08:34:28 2010].533766 freeLayer(): freeing layer at 0x8630840.
[Tue Jul 27 08:34:28 2010].534630
msConnPoolClose(RWS_LEZEN/RWS_LEZEN at geodatabase.ad.rws.nl:1521/PGPR.rws.nl,0x87722b0)
Layer string is:
    CONNECTION "RWS_LEZEN/xxx at geodatabase.ad.rws.nl:1521/PGPR.rws.nl"
    CONNECTIONTYPE ORACLESPATIAL
    DATA "SHAPE FROM (SELECT OBJECTID, HECTARES, ZONENR, NULZONES, AREA,
PERIMETER, SHAPE FROM GRENZEN.OV_ZONERING) USING UNIQUE OBJECTID"
Best regards,
Bart
Looking for flexible support on OpenLayers or GeoExt? Please check out
http://www.osgis.nl/support.html
OSGIS
bartvde at osgis.nl
