[mapserver-dev] Light Speed Map Server
Jeff McKenna
jmckenna at gatewaygeomatics.com
Wed Jul 28 08:27:19 EDT 2010
It would be great if you could add this as a new wiki page on the
MapServer wiki (see the lower section of
http://trac.osgeo.org/mapserver/). That way others can find this
document, and maybe even add to it over the years. Thanks!
-jeff
Jeff McKenna
MapServer Consulting and Training Services
http://www.gatewaygeomatics.com/
> This is a configuration of Map Server <http://mapserver.org?by-user=t>
> WMS as fast-cgi <http://www.fastcgi.com?by-user=t> module of Lighttpd
> <http://www.lighttpd.net?by-user=t>. Here I am compiling all main
> software packages from the source code on a 64bit Linux operating system
> to get maximum performance. I hope my readers having experience in
> installing & configuring software packages under Linux platform. I
> prefer a CentOS 5.4 ×86_64 <http://www.centos.org?by-user=t> Linux
> minimal server installation, because it is quite stable for me so far.
> Prerequisites
> Make sure that you have installed the following packages, normally it
> comes with the operating system installation.
> cc gcc-c++ python python-devel krb5-devel readline-devel make
> swig pcre-devel libpng libpng-devel bzip2-devel fontconfig
> fontconfig-devel libxml2-devel penssl-devel curl-devel
> giflib-devel zlib-devel gettext libjpeg-devel libtiff-devel
> If any of the package is not installed, install it by using YUM. For
> example if gcc is missing
> yum install gcc-c++
> Ok, let’s start with the main software packages installation for Map
> Server,
> PostgresSQL
> The world’s most advanced open source database server.I prefer
> PostgresSQL <http://www.postgresql.org?by-user=t> server to store the
> vector map data, for fast searching and rendering of WMS map tiles.
> Download the source
> <http://nishad.us/docs/softwares/postgresql-8.4.2.tar.gz>
> Installation & Configuration.
> tar -xzf postgresql-8.4.2.tar.gz
> cd postgresql-8.4.2/
> ./configure —prefix=/usr/local/pgsql —with-perl —with-python
> —with-krb5
> make
> make install
> adduser postgres
> mkdir /var/lib/pgsql
> chown -R postgres /var/lib/pgsql
> su postgres
> /usr/local/pgsql/bin/initdb -D /var/lib/pgsql/data
> /usr/local/pgsql/bin/postgres -i -h localhost -p 5432 -D
> /var/lib/pgsql/data &
> Now your PostgreSQL server is up and running. If you need an init.d
> startup script, download it from here /etc/init.d/postgresql
> <http://nishad.us/docs/softwares/postgresql.txt>
> FastCGI
> FastCGI <http://www.fastcgi.com?by-user=t> is a protocol for interfacing
> interactive programs with a web server. This is a variation on the
> earlier Common Gateway Interface (CGI). Unlike CGI, It cannot duplicates
> the universality of CGI overnight. It runs applications in processes
> isolated from the core Web server, which provides greater security than
> APIs. Not only does FastCGI restore the strengths of CGI, it also adds
> two new benefits like Distributed computing and Multiple extensible roles.
> Download the source <http://nishad.us/docs/softwares/fcgi-2.4h4>. PROJ.4
> Proj.4 <http://trac.osgeo.org/proj/> is Cartographic Projections library
> is designed as a standard Unix filter utility to be employed with other
> pro-grams in the generation of maps and charts and, in many cases, used
> in map digitizing applications for conversion of State Plane Coordinate
> Systems to and from geographic coordinates.
> Download the source <http://nishad.us/docs/softwares/proj-4.7.0.tar.gz>
> tar -xzf proj-4.7.0.tar.gz
> cd proj-4.7.0/
> make
> make install
> You have successfully compiled the Proj4 libraries required for Map
> Server..0.tar.gz
> tar -xzf fcgi-2.4.0.tar.gz
> cd fcgi-2.4.0/
> make
> make install
> You have installed the FastCGI executables and libraries now, we will
> use this later while configuring the Map Server.
> LighHTTPD
> Lighttpd <http://www.lighttpd.net/> is a web server designed and
> optimized for high performance environments, with a small memory
> footprint compared to other web-servers and effective management of the
> cpu-load. This is a perfect solution for every server which is suffering
> load problems.
> Download the source <http://nishad.us/docs/softwares/lighttpd-1.4.26.tar.gz>
> tar -xzf lighttpd-1.4.26.tar.gz
> cd lighttpd-1.4.26/
> p<>. ./configure —prefix /usr/local/ —bindir=/usr/local/bin/
> —sbindir=/usr/local/sbin/ —libexecdir=/usr/local/libexec/
> —libdir=/usr/local/lib/ —includedir=/usr/local/include
> —sysconfdir=/usr/local/lighthttpd —datarootdir=/var/www/
> —datadir=/var/www —with-memcache
> make
> make install
> install -Dp ./doc/lighttpd.conf /etc/lighttpd/lighttpd.conf
> sed -e ‘s/FOO/lighttpd/g’ doc/rc.lighttpd.redhat >
> /etc/init.d/lighttpd
> chmod a+rx /etc/init.d/lighttpd
> /etc/init.d/lighttpd start
> You have successfully compiled and configured your fast & secure
> Lighttpd web server.
> PROJ.4
> cd proj-4.7.0/
> make
> make install
> You have successfully compiled the Proj4 libraries required for Map Server.
> FreeType
> FreeType <http://www.freetype.org/> is a software font engine that is
> designed to be small, efficient, highly customizable, and portable while
> capable of producing high-quality output. It can be used in graphics
> libraries, display servers, font conversion tools, text image generation
> tools, and many other products as well.
> Download the source <http://nishad.us/docs/softwares/freetype-2.3.12.tar.gz>
> tar -xzf freetype-2.3.12.tar.gz
> cd freetype-2.3.12/
> make
> make install
> You have successfully compiled the FreeType libraries required for Map
> Server.
> GEOS
> Geos <http://trac.osgeo.org/geos/> GEOS is a Geometry Engine which aims
> to contain the complete functionality of Java Topology Suite. This
> includes all the GIS Simple Features for SQL spatial predicate functions
> and spatial operators, as well as specific JTS enhanced topology functions.
> Download the source <http://nishad.us/docs/softwares/geos-3.2.0.tar.bz2>
> tar -xjf geos-3.2.0.tar.bz2
> cd geos-3.2.0/
> ./configure —prefix=/usr/local/ —enable-python —enable-swig
> make
> make install
> You have successfully compiled the Geos libraries required for Map Server.
> GD
> GD <http://www.libgd.org?by-user=t> is used for dynamic creation of
> images like PNG, JPEG and GIF images, among other formats. GD is
> commonly used to generate charts, graphics, thumbnails, and most
> anything else, on the fly.
> Download the source <http://nishad.us/docs/softwares/gd-2.0.35.tar.gz>
> tar -xzf gd-2.0.35.tar.gz
> cd gd-2.0.35/
> ./configure —prefix=/usr/local/ —with-png=/usr/
> —with-jpeg=/usr/local/ —with-fontconfig=/usr/
> make
> make install
> You have successfully compiled the GD binaries and it’s libraries
> PHP
> PHP <http://php.net?by-user=t> is a widely-used general-purpose
> scripting language that is especially suited for Web development and can
> be embedded into HTML. Here we are configuring PHP with PostgreSql and
> GD with is required for PHP mapscript, and compiling as fast-cgi to get
> the maximum security and speed.
> Download the source <http://nishad.us/docs/softwares/php-5.3.2.tar.gz>
> tar -xzf php-5.3.2.tar.gz
> cd php-5.3.2/
> ./configure —prefix=/usr/local/php5 —with-fastcgi=/usr/local
> —with-regex=php —enable-debug —enable-magic-quotes
> —enable-libgcc —with-libxml-dir=/usr/local/ —with-openssl=/usr
> —with-kerberos=/usr/local/ —with-zlib=/usr —with-bz2=/usr/local/
> —with-curl=/usr/local/ —with-gettext=/usr/local/
> —enable-mbstring —with-pgsql=/usr/local/pgsql/ —enable-soap
> —enable-zip —with-gd=/usr/local/ —with-jpeg-dir=/usr/local/
> —with-png-dir=/usr/local/ —with-mhash=/usr/local/
> make
> make install
> cp -pr php.ini-production /usr/local/php5/lib/php.ini
> You have successfully compiled PHP as fast-cgi in the server.
> PostGIS
> PostGIS <http://postgis.refractions.net/> PostGIS adds support for
> geographic objects to the PostgreSQL object-relational database. In
> effect, PostGIS “spatially enables” the PostgreSQL server, allowing it
> to be used as a backend spatial database for geographic information
> systems (GIS).
> Download the source <http://nishad.us/docs/softwares/postgis-1.5.1.tar.gz>
> tar -xzf softwares/postgis-1.5.1.tar.gz
> cd postgis-1.5.1/
> —with-geosconfig=/usr/local/bin/geos-config
> —with-pgsql=/usr/local/pgsql/bin/pg_config
> make
> make install
> You have successfully configured postGIS with PostgreSQL and Geos,
> compiled the source and installed the binaries. Now you create a
> PostgreSQL database and spatially enables it by importing the PostGIS
> sql functions.
> createdb -U postgres testgis
> createlang -U postgres plpgsql testgis
> psql -U postgres testgis < postgis/postgis.sql
> psql -U postgres testgis < spatial_ref_sys.sql
> GDAL
> GDAL <http://www.gdal.org?by-user=t> (Geospatial Data Abstraction
> Library) is a library for reading and writing raster geospatial data
> formats. As a library, it presents a single abstract data model to the
> calling application for all supported formats. It may also be built with
> a variety of useful command-line utilities for data translation and
> processing.
> Download the source <http://nishad.us/docs/softwares/gdal-1.7.1.tar.gz>
> tar -xzf gdal-1.7.1.tar.gz
> cd gdal-1.7.1/
> —with-libtiff=/usr/local/ —with-jpeg=/usr/local/ —with-gif=/usr/
> —with-pg=/usr/local/pgsql/bin/pg_config —with-geos=/usr/local/
> —with-python
> make
> make install
> You have successfully compiled Gdal with png,tiff,jpeg,gif,PostgreSQL
> and python. Now your Gdal library is available to build the Map Server.
> Map Server
> Map Server <http://mapserver.org?by-user=t> MapServer is geographic data
> rendering engine, providing spatial context where needed. It allows you
> to create geographic image maps that can direct users to content. It was
> originally developed by the University of Minnesota (UMN) ForNet project
> in cooperation with NASA. The main features are,
> * Advanced cartographic output
> * Scale dependent feature drawing and application execution
> * Feature labeling including label collision mediation
> * Fully customizable, template driven output
> * TrueType fonts
> * Map element automation (scalebar, reference map, and legend)
> * Thematic mapping using logical- or regular expression-based classes
> * Support for popular scripting and development environments, ie
> PHP, Python, Perl, Ruby, Java.
> * Cross-platform support
> * Support of numerous Open Geospatial Consortium (OGC) standards, ie
> WMS,WFS, WMC, WCS, Filter Encoding, SLD, GML, SOS, OM
> * A multitude of raster and vector data formats, ie TIFF/GeoTIFF,
> EPPL7, ESRI shapfiles, PostGIS, ESRI ArcSDE, Oracle Spatial, MySQL
> * On-the-fly map projection with 1000s of projections through the
> Proj.4 library.
> Download the source <http://nishad.us/docs/softwares/mapserver-5.6.1.tar.gz>
> tar -xzf mapserver-5.6.1.tar.gz
> cd mapserver-5.6.1/
> —with-gdal=/usr/local/bin/gdal-config
> —with-ogr=/usr/local/bin/gdal-config
> —with-httpd=/usr/local/sbin/lighttpd
> —with-curl=/usr/bin/curl-config —enable-debug
> —with-proj=/usr/local/ —with-tiff=/usr/ —with-gd=/usr/local/
> —with-jpeg=/usr/local/ —with-freetype=/usr/local/ —with-threads
> —with-postgis=/usr/local/pgsql/bin/pg_config
> —with-xml2-config=/usr/bin/xml2-config —with-png=/usr/
> —with-wmsclient —with-wmsserver —with-fastcgi=/usr/local/
> —with-wfs with-wfsclient —with-gif=/usr/
> —with-geos=/usr/local/bin/geos-config —with-php=/usr/local/php5
> make
> make install
> cp -pr mapserv /var/www/cgi-bin/
> You have successfully compiled the Map Server with all it’s
> prerequisites and bindings,and as fast-cgi binary. Now you can test your
> installation by running “mapserv” binary. If you get below output, it
> seems your installation is successful.
> ./mapserv -v
> MapServer version 5.6.1 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG
> OUTPUT=WBMP OUTPUT=SVG SUPPORTS=PROJ SUPPORTS=AGG
> SUPPORTS=FREETYPE SUPPORTS=ICONV SUPPORTS=WMS_SERVER
> SUPPORTS=WMS_CLIENT SUPPORTS=WFS_SERVER SUPPORTS=FASTCGI
> SUPPORTS=THREADS SUPPORTS=GEOS INPUT=TIFF INPUT=EPPL7
> INPUT=POSTGIS INPUT=OGR INPUT=GDAL INPUT=SHAPEFILE
> PHP & Map server FastCGI configuration with Lighttpd. Edit Lighttpd.conf,
> vi /etc/lighttpd/lighttpd.conf
> and insert below configuration under the fastcgi section.
> fastcgi.server = ( “.php” =>
> ( “localhost” =>
> “socket” => “/tmp/php-fastcgi.socket”,
> “bin-path” => “/usr/local/php5/bin/php-cgi”
> “/map” =>
> ( “localhost” =>
> “socket” => “/tmp/mapserver-fastcgi.socket”,
> “bin-path” => “/var/www/cgi-bin/mapserv”,
> “max-procs” => 1,
> “check-local” => “disable”
> Restart your Lighttpd server.
> /etc/init.d/lighttpd restart
> Your Light Speed FastCGI Map Server Web Map Service(WMS) is up and
> running now. :) Try it from the URL
> http://localhost/maps?map=yourmapfile.map
> Contact me for any further help.
> Nishad Aliyar
> nishad.n.a at gmail.com <mailto:nishad.n.a at gmail.com>
