[mapserver-dev] MapFile generator?
thomas bonfort
thomas.bonfort at gmail.com
Thu Mar 18 09:09:06 EDT 2010
If you're looking for a mapfile editor that doesn't rely on on
mapscript, you might want to have a look at http://www.geojava.org/
it has it's own mapfile model and will let you:
- export / publish your created mapfile
- explore your data layers
- edit and test your symbology
thomas
On Wed, Mar 17, 2010 at 20:58, Mulone <mulone at rome.com> wrote:
> Hi guys,
> I'm trying to set up a mapfile generator to generate a customised mapfile
> for different users in my system. Our system is written in Java/Groovy, so
> it would seem quite natural to me to set up a few classes modelling the
> mapfile content (classes, layers with all the options), and then manipulate
> these objects in my app (e.g. show/hide layers, change styles, scales, etc),
> and then call a simple "genMapfile()" and write everything to a temp file,
> then read by mapserver a few millisecs afterwards.
> This looks quite simple to do.
> My point is: do you know of any Java/Groovy generator of mapfiles? If not,
> do you think it could be interesting for you if I set up a google-code
> project on this idea? Do you think this is a sensible solution to my
> problem?
> Thanks for any comment!
> Mulone
> Mulone
> PhD student
> View this message in context: http://n2.nabble.com/MapFile-generator-tp4752655p4752655.html
> Sent from the Mapserver - Dev mailing list archive at Nabble.com.
> mapserver-dev mailing list
> mapserver-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapserver-dev
