[mapserver-dev] Proposing some homepage changes...
Daniel Morissette
dmorissette at mapgears.com
Fri May 7 11:51:22 EDT 2010
Hi Steve, Jeff,
I just wanted to add that I like the changes you are suggesting and are
working on.
Thanks
Daniel
Jeff McKenna wrote:
> Hi Steve,
> I fully agree with you.
> I made some minor changes so that the announcement sections no longer
> appear in the TOC: http://www.mapserver.org/
> I also made an attempt to clean up the left sidebar nav, with the
> sections that you suggested, through our Sphinx layout template:
> http://www.mapserver.org/trunk/en/index.html
> Impressions/comments?
> Personally, I like it better. What I don't like is the "Table of
> Contents" section that still remains on that index page - oh I tried to
> remove it, searching the Sphinx Google group, trying many different
> ways, but in the end I failed to remove it. It only appears on some
> pages though.
> It's a start?
> -jeff
> Lime, Steve D (DNR) wrote:
>> Hi all: I'd like to propose some changes to the mapserver.org
>> homepage. Wondering how feasible they'll be via Sphinx:
>> - Breadcrumb. Really should start at "Home" and then go from there,
>> e.g.:
>> Home >> Documentation >> MapScript or
>> Home >> FAQ
>> Home >> Develelopment >> RFCs
>> - TOC on the homepage shouldn't be announcements but rather
>> something like:
>> Community
>> Mailing Lists
>> IRC
>> Wiki
>> Development Documentation
>> Introduction
>> FAQ
>> Mapfiles
>> MapScript
>> Downloads
>> Issue Tracker
>> - Announcements could continue below the fold on the main part of
>> the homepage
>> It's not user friendly as is. The shorter, more meaningful TOC would
>> also help to pull the OSGEO and FOSS4G icons up the page. Thoughts?
> mapserver-dev mailing list
> mapserver-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapserver-dev
Daniel Morissette
http://www.mapgears.com/
