[mapserver-dev] PostGIS "curvepolygon" support
Astrid Emde astrid.emde at wheregroup.com
Mon Nov 8 11:46:53 EST 2010
Hello Paul,
thanks for your answer.
I would favorite the solution b) to make the functionality generally
available.
But just a question - we always will have the process of stroking
PostGIS curves which will be a performance leak. Am I right?
At the moment we preprocess our data and create the strokes in the
database in a second geom_column. So we loose no performance as we
access the preprocessed data in our mapfiles. Solution b) will still do
the "stroke-processing" on-the-fly.
Frank offered to implement a solution in GDAL/OGR so this would be for
CONNECTIONTYPE OGR and the solution you suggested would be for
CONNECTIONTYPE POSTGIS. Is this right?
Astrid
Paul Ramsey schrieb:
> Astrid,
> It would make sense to generally handle the curvey types in the run,
> including the compoundcurve and circularstring as forms of mapserver
> LINE types. I think your thread suggestion is correct (perhaps?) in
> that it would be "simplest" to just paper over the curve types in the
> postgis driver. This is in fact what is happening (sort of) in the
> Oracle driver already.
> The papering-over could take two forms.
> (a) We could change the SQL being send to PostGIS to ensure that
> curves are stroked (turned into equivalent linestrings) on the
> database side.
> (b) Or we could extract the stroking routines that have already been
> written in the Oracle driver to a globally accessible area, genericize
> them a little, and use them to stroke PostGIS curves in the MapServer
> code.
> The advantage of (b) is that the stroking routines would then be
> generically available to any other driver that needs to stroke curves.
> It would be a little more work than hacking up the SQL generated by
> the PostGIS driver to get the server to do the work of stroking.
> Does anyone else have interest in this issue?
> Paul
> On Mon, Nov 8, 2010 at 11:06 PM, Astrid Emde <astrid.emde at wheregroup.com> wrote:
>> Hello devs,
>> there was a discussion going on about PostGIS "curvepolygon" support for
>> MapServer. At the moment polygons without curves are
>> drawn, the ones with curves not.
>> Here is the discussion link:
>> http://osgeo-org.1803224.n2.nabble.com/PostGIS-curvepolygon-support-tt5372049.html
>> One of our customers would like to sponsor this implementation and would
>> like to know how much this enhancement would cost. It would be good if you
>> could handle polygons and curevepolygons in one MapServer layer from TYPE
>> POLYGON.
>> In the thread there was also the discussion about a solution which is
>> implemented in the PostGIS driver ...
>>>  Curiously could this mean adding to the PostGIS driver a means of
>>>  going from curve to shapeObj? As opposed to adding a curve shape
>>>  type within MapServer.
>> Could you please discuss a possible solution and estimate the costs? Who
>> would be the contact person concerning this enhancement?
>> Maybe there are other MapServer users interested in this enhancement and
>> would also sponsor the implementation.
>> Best regards
>> Astrid Emde
>> Aufwind durch Wissen!
>> Qualifizierte OpenSource-Schulungen
>> bei der www.foss-academy.eu
>> Astrid Emde
>> WhereGroup GmbH & Co.KG
>> Siemensstraße 8
>> 53121 Bonn
>> Germany
>> Fon: +49(0)228 90 90 38 - 19
>> Fax: +49(0)228 90 90 38 - 11
>> www.wheregroup.com
>> Amtsgericht Bonn, HRA 6788
>> Komplementärin:
>> WhereGroup Verwaltungs GmbH
>> vertreten durch:
>> Olaf Knopp, Peter Stamm
>> mapserver-dev mailing list
>> mapserver-dev at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapserver-dev
Mit freundlichen Grüßen
Astrid Emde
 Astrid Emde
 Siemensstraße 8
 53121 Bonn
 Germany
 www.wheregroup.com
Komplementärin:
vertreten durch:
