[mapserver-dev] 6.0 release plan
Lime, Steve D (DNR) Steve.Lime at state.mn.us
Mon Nov 8 19:56:25 EST 2010
Queries can apply to one or more layers, so it's a map level deal. Layers wouldn't be processed to the msLayerWhichShapes() point unless a query or drawing operation applied to that layer.
Steve
________________________________________
Sent: Monday, November 08, 2010 4:50 PM
To: Lime, Steve D (DNR)
Cc: mapserver-dev at lists.osgeo.org
Subject: Re: [mapserver-dev] 6.0 release plan
2010/11/8 Lime, Steve D (DNR) <Steve.Lime at state.mn.us<mailto:Steve.Lime at state.mn.us>>
Regarding one-pass, would the contents of the queryObj suffice? It fully encapsulates the query (if it is indeed a query being done) and would be accessible through the layer’s pointer back to the parent mapObj (layer->map->query).
I thought it was rather a layer level parameter than map level. It could however be good as far as it is set before each whichShapes call (not only with the feature queries but in a normal drawing as well), and should also be exposed to the mapscript API.
Tamas
