[mapserver-dev] 6.0 release plan
Tamas Szekeres
szekerest at gmail.com
Mon Nov 8 17:50:29 EST 2010
2010/11/8 Lime, Steve D (DNR) <Steve.Lime at state.mn.us>
> Regarding one-pass, would the contents of the queryObj suffice? It fully
> encapsulates the query (if it is indeed a query being done) and would be
> accessible through the layer’s pointer back to the parent mapObj
> (layer->map->query).
I thought it was rather a layer level parameter than map level. It could
however be good as far as it is set before each whichShapes call (not only
with the feature queries but in a normal drawing as well), and should also
be exposed to the mapscript API.
Tamas
URL: http://lists.osgeo.org/pipermail/mapserver-dev/attachments/20101108/4a91e73c/attachment.html
