[mapserver-dev] OpenGL check in
Toby Rahilly toby.rahilly at gmail.com
Wed Nov 17 06:47:04 EST 2010
> symbols used as a brush smoothly along a line: this isn't
> implemented in the plugin renderers, as only agg supports it. todo.
Ok good to know. OpenGL is ready to support this.
Cheers,
Toby
This email was sent from my mobile.
On 17/11/2010, at 7:38 PM, thomas bonfort <thomas.bonfort at gmail.com> wrote:
> On Wed, Nov 17, 2010 at 12:31, Toby Rahilly <toby.rahilly at gmail.com> wrote:
>> I have checked in the Opengl update to the mapserver6 sandbox.
>> Still TO DO:
>> * Optimized by using textures for symbols and not creating an OpenGL
>> context for every new image.
>> * I was not able to get line symbols to work in any renderer, have
>> they changed for Mapserver 6?
> what kind of line symbols are you referring to?
> - marker symbols placed along a line (that would be a bug worth investigating)
> - symbols used as a brush smoothly along a line: this isn't
>> I have tested on Windows 7 and Ubuntu 8 both with Nvidia drivers.
>> Any testing on other platforms/video cards would be greatly
>> appreciated, thanks Tamas! You will need to compile with the FTGL
>> library which is used for text rendering. The driver is "OGL".
>> You can compare some renderings here:
>> agg: http://www.flickr.com/photos/convolous/5184383842/
>> opengl: http://www.flickr.com/photos/convolous/5184384174/
> any info on the timings using each renderer?
> cheers,
> thomas
>> Cheers,
>> Toby
>> On Sat, Nov 13, 2010 at 6:51 PM, Tamas Szekeres <szekerest at gmail.com> wrote:
>>> I'll be happy to do some testing on Windows as soon as  the implementation
>>> is complete.
>>> Best regards,
>>> Tamas
>>> 2010/11/13 Toby Rahilly <toby.rahilly at gmail.com>
>>>>> RFC-50: I think this is out for 6.0 unless those authors are still
>>>>> around.
>>>> When I left the OpengGL implementation was pretty much done. Todo is
>>>> 1) Updating for the changing graphics rendering API
>>>> 2) Cross platform OpenGL context creation support and testing
>>>> The actual rendering code is done.
>>>> Jon and I think we can finish it up before the 15th and will be having
>>>> a go over the weekend. If its not ready for the 6.0 feature freeze,
>>>> we'll try to leave it in a good state for the next release.
>>>> Cheers,
>>>> Toby
>>>> On Tue, Nov 9, 2010 at 1:07 AM, Lime, Steve D (DNR)
>>>>> around.
>>>>> RFC-52: The changes I’d like to see are relatively minor (from a coding
>>>>> perspective) and are a return to a single getShape() method in
>>>>> MapScript. It
>>>>> will break 5.6 scripts but is simpler in the long run. I don’t know that
>>>>> an
>>>>> RFC is necessary but I will start a ticket and we can go from there.
>>>>> RFC-54: I think Thomas just needs to merge?
>>>>> RFC-58 – RFC-63: Are all basically complete, perhaps need docs though.
>>>>> RFC-64: Needs feedback. This may push us back a week or two depending on
>>>>> feedback. I think 6.0 is the right time to implement though given the
>>>>> types
>>>>> of proposed changes. They are not candidates for minor releases.
>>>>> Thanks for pushing on this…
>>>>> Steve
>>>>> From: mapserver-dev-bounces at lists.osgeo.org
>>>>> [mailto:mapserver-dev-bounces at lists.osgeo.org] On Behalf Of Tamas
>>>>> Szekeres
>>>>> Sent: Saturday, November 06, 2010 6:12 PM
>>>>> To: mapserver-dev at lists.osgeo.org
>>>>> Subject: [mapserver-dev] 6.0 release plan
>>>>> Hi All,
>>>>> In search of my memory (and my mails) the recent plan of the 6.0 release
>>>>> has
>>>>> been scheduled as follows:
>>>>> "Plan for a feature freeze on Nov 15th, with a little over 2 months for
>>>>> betas, aiming for final release between Jan 15th and 31st"
>>>>> How do we stand with the upcoming activities in the light of this?
>>>>> I can see the following RFCs may be affected or must be scheduled:
>>>>> RFC-50 (OpenGL)
>>>>> RFC-52 (One-pass query processing), we wanted to do some rework as far
>>>>> as I
>>>>> remember.
>>>>> RFC-54 (Rendering overhaul)
>>>>> RFC-58 (KML output)
>>>>> RFC-62 (Additional WFS GetFeature Output Formats)
>>>>> RFC-63 (OpenLayers viewer)
>>>>> RFC-64 (Expression parser overhaul)
>>>>> Do we have any other plan which will be covered with an RFC soon? How
>>>>> much
>>>>> time the pending efforts will take to be implemented?
>>>>> The 6.0 release plan document may also updated with some up to date
>>>>> information if possible.
>>>>> Best regards,
>>>>> Tamas
>>>>> _______________________________________________
>>>>> mapserver-dev mailing list
>>>>> http://lists.osgeo.org/mailman/listinfo/mapserver-dev
