[mapserver-dev] RFC 65 - Single pass query handling for 6.0
Lime, Steve D (DNR)
Steve.Lime at state.mn.us
Mon Nov 29 00:07:01 EST 2010
FYI I updated RFC 65 with a bit more detail on implementation and impact... Again, feedback most welcome.
Steve
________________________________________
From: Yewondwossen Assefa [yassefa at dmsolutions.ca]
Sent: Tuesday, November 23, 2010 4:23 PM
To: Lime, Steve D (DNR)
Cc: mapserver-dev at lists.osgeo.org
Subject: Re: [mapserver-dev] RFC 65 - Single pass query handling for 6.0
So ogr layers would use return (after a query) shape->index as the global/unique index and shape->tileindex as a tileindex? Or would they stay as It is in 5.6 (use the shape->index as the relative index from the query)?
On 23/11/2010 4:43 PM, Lime, Steve D (DNR) wrote:
Drivers that support tile indexes would continue to work “as-is”. Those drivers aren’t database driven so they, like shapefiles, would continue to use shape and tile indexes to retrieve records for presentation. The only way adding an additional index would make sense to me is if we relied on a result set object and passed it to getShape() or getFeature() in mapscript.
Steve
From: Yewondwossen Assefa [mailto:yassefa at dmsolutions.ca]
Sent: Tuesday, November 23, 2010 2:28 PM
Cc: mapserver-dev at lists.osgeo.org<mailto:mapserver-dev at lists.osgeo.org>
Hi Steve,
Regarding the use of tileindex as the shape index relative to a query: would this work when users define TILEINDEX in their map file (I think that is what its is used for?) Would it be better to have an additional new field?
I really think that additional MapScript save/load queries a la pre-5.6 are a welcome changes.
regards,
On 22/11/2010 12:42 PM, Lime, Steve D (DNR) wrote:
Hi all: I jotted down some thoughts on changes I’d like to see made for 6.0 that address shortcomings to the 5.6 single pass query
handling. I’m looking to simplify… We have to do something for this release on the topic. I don’t think the proposed changes will
take much effort.
http://mapserver.org/development/rfc/ms-rfc-65.html
Steve
mapserver-dev mailing list
http://lists.osgeo.org/mailman/listinfo/mapserver-dev
Assefa Yewondwossen
Software Analyst
Email: yassefa at dmsolutions.ca<mailto:yassefa at dmsolutions.ca>
http://www.dmsolutions.ca/
Phone: (613) 565-5056 (ext 14)
Fax: (613) 565-0925
Assefa Yewondwossen
Software Analyst
Fax: (613) 565-0925
