[mapserver-dev] RFC 62: Support Additional WFS GetFeature OutputFormats
Yewondwossen Assefa yassefa at dmsolutions.ca
Tue Oct 12 12:45:26 EDT 2010
  Sorry to  comment late on this issue:
  - could a  wfs_formats defined at  the map level be allowed if none
was defined at the layer level?
  - I also want to suggest maybe using wfs_getfeature_formatlist since
that was what was used for wms and described in bug 3172 [1]
best regards,
[1]: https://trac.osgeo.org/mapserver/ticket/3172
>> Note I haven't mentioned anything about a wfs_formats metadata item.
>> Were you thinking this would list a set of formats that would be
>> permitted for WFS GetFeature()?  As currently specified I think WFS
>> GetFeature would support any templates defined via OUTPUTFORMAT,
>> the traditional GML2 and GML3 values and any OGR OUTPUTFORMATs defined
>> in the map file.  In fact, I can see that it would be quite helpful
>> to restrict the set of output formats supported by WFS for particular
>> layers.  So despite the start of voting, I'm going to update the RFC to:
> Jeff,
> OK, rereading my own specification I see I was wrong - I had already
> introduce a wfs_formats metadata item and then flushed it from my brain!
> the values in the wfs_formats name will be the "NAME" parameter from the
> OUTPUTFORMAT declaration.  So in case of a format like:
> OUTPUTFORMAT
>   NAME "MSCSV"
>   DRIVER "OGR/CSV"
>   MIMETYPE "text/csv"
>   FORMATOPTION "LCO:GEOMETRY=AS_WKT"
>   FORMATOPTION "STORAGE=filesystem"
>   FORMATOPTION "FORM=simple"
>   FORMATOPTION "FILENAME=result.csv"
> END
> The value in wfs_formats would be "MSCSV". I will clarify this in the
> RFC.
> Best regards,
Assefa Yewondwossen
Software Analyst
Email: yassefa at dmsolutions.ca
http://www.dmsolutions.ca/
Phone: (613) 565-5056 (ext 14)
Fax:   (613) 565-0925
