[mapserver-dev] RFC 62: Support Additional WFS GetFeature
OutputFormats
Frank Warmerdam
warmerdam at pobox.com
Tue Oct 12 11:41:14 EDT 2010
Frank Warmerdam wrote:
> Note I haven't mentioned anything about a wfs_formats metadata item.
> Were you thinking this would list a set of formats that would be
> permitted for WFS GetFeature()? As currently specified I think WFS
> GetFeature would support any templates defined via OUTPUTFORMAT,
> the traditional GML2 and GML3 values and any OGR OUTPUTFORMATs defined
> in the map file. In fact, I can see that it would be quite helpful
> to restrict the set of output formats supported by WFS for particular
> layers. So despite the start of voting, I'm going to update the RFC to:
Jeff,
OK, rereading my own specification I see I was wrong - I had already
introduce a wfs_formats metadata item and then flushed it from my brain!
the values in the wfs_formats name will be the "NAME" parameter from the
OUTPUTFORMAT declaration. So in case of a format like:
OUTPUTFORMAT
NAME "MSCSV"
DRIVER "OGR/CSV"
MIMETYPE "text/csv"
FORMATOPTION "LCO:GEOMETRY=AS_WKT"
FORMATOPTION "STORAGE=filesystem"
FORMATOPTION "FORM=simple"
FORMATOPTION "FILENAME=result.csv"
END
The value in wfs_formats would be "MSCSV". I will clarify this in the RFC.
Best regards,
and watch the world go round - Rush | Geospatial Programmer for Rent
