[mapserver-dev] Checking the use of a qix file
Lime, Steve D (DNR) Steve.Lime at state.mn.us
Thu Sep 2 11:39:53 EDT 2010
Thanks Dan. I can't tell from that image is we're dropping features when processing or not, the images looks to be just the visualization output. Just trying to gauge the significance...
-----Original Message-----
From: mapserver-dev-bounces at lists.osgeo.org [mailto:mapserver-dev-bounces at lists.osgeo.org] On Behalf Of Daniel Morissette
Sent: Thursday, September 02, 2010 10:35 AM
To: 'MapServer Dev Mailing List'
Subject: Re: [mapserver-dev] Checking the use of a qix file
Lime, Steve D (DNR) wrote:
> I guess I'd draw the map (e.g. indexed data) and overlay it with the shapetreevis output. If the features are in the map (and the index was used, so you'd have to zoom in a bit) but there's no quadrant data then it's a shapetreevis issue. How do you know quadrants are missing? I mean, how are you testing in the first place...
A bit of context will help understand the issue. See the following post
from the Benchmarking list and look at the image linked at the bottom of it:
http://lists.osgeo.org/pipermail/benchmarking/2010-September/000787.html
I believe Frank is already looking into this based on what I read on the
#foss4g channel on irc.freenode.net
Daniel
Daniel Morissette
http://www.mapgears.com/
mapserver-dev mailing list
mapserver-dev at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/mapserver-dev
