[mapserver-dev] Proposal to add built-in OpenLayers map viewer
Tamas Szekeres
szekerest at gmail.com
Fri Sep 24 17:46:29 EDT 2010
Daniel,
Adding a viewer with zoom and pan capabilities is a good idea which is
better then having a single image in some cases. I foresee a reasonable Web
administration interface to mapserver could also be established by such
additions which would be a requirement too.
However embedding code from a separate project seems to be a hassle, though
the technical solution hasn't yet been mentioned in the ticket.
I would be in favour of doing either:
1. Create a simple (mapserver specific) .js to provide the required
functionality (which could be extended later with further options)
2. Provide a (pluggable) interface for use by the potential viewers in
mapserver, and create a separate support package for at least one (like
openlayers for instance) and include the external code to this package.
(Just to put my 2 cents in)
Best regards,
Tamas
2010/9/24 Daniel Morissette <dmorissette at mapgears.com>
> This was discussed at the code sprint in Barcelona, and I just created a
> ticket for it. We'd like to add this to 6.0... but I am realizing just
> now that maybe I should start with a RFC...
> Anyway, here is what I wrote in the ticket, please feel free to comment,
> keeping in mind this has to remain __simple__:
> http://trac.osgeo.org/mapserver/ticket/3549
> Every once in a while we get requests for a simple way to test a
> mapfile. One way to handle this could be to do as GeoServer does and
> provide a built-in OpenLayers based map viewer. In the GeoServer case,
> this viewer is returned when one issues a WMS GetMap request with
> format=application/openlayers in it.
> I propose that we provide a similar functionality in MapServer, which
> would be triggered in one of two ways:
> 1- Using mapserv?map=/path/to/my.map&'''mode=openlayers''' ... in this
> case the viewer would be initialized based on the mapfile defaults, and
> some of the traditional mapserv CGI params may also work (such as map
> size, layer selection, etc.)
> 2- Using '''format=application/openlayers''' in a WMS GetMap request as
> GeoServer does. Note that in this case the rest of the GetMap parameters
> would be used to configure the map to view (BBOX, WIDTH, HEIGHT, LAYERS,
> etc.)
> Both cases would call the same function internally to produce a simple
> OpenLayeres viewer with one singletile layer for the whole map with the
> selected layers.
> Daniel Morissette
> http://www.mapgears.com/
> mapserver-dev mailing list
> mapserver-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapserver-dev
URL: http://lists.osgeo.org/pipermail/mapserver-dev/attachments/20100924/fd6e8b85/attachment.html
