[mapserver-dev] Proposal to add built-in OpenLayers map viewer
Daniel Morissette
dmorissette at mapgears.com
Mon Sep 27 14:27:21 EDT 2010
Bob Basques wrote:
> I don't see the TEMPLATE route as being any more (or less) of a problem
> in adding as a method to achieve the desired results, and it leaves a
> measure of flexibility behind as well. I mean if you need a MAPFILE
> anyway, what's the difference in adding a TEMPLATE for use as well.
I'm sorry but I don't get it... what is "the template route"... and what
does it allow you to do that you cannot already do today with MapServer
5.6.x?
Daniel Morissette
http://www.mapgears.com/
