[mapserver-dev] MOTION: Symbol-level keyword removal
Lime, Steve D (DNR)
steve.lime at state.mn.us
Fri Apr 1 15:59:29 EDT 2011
+1... Assefa, I have the RFC work on references that Schuyler started around some place.
Steve
-----Original Message-----
From: mapserver-dev-bounces at lists.osgeo.org [mailto:mapserver-dev-bounces at lists.osgeo.org] On Behalf Of Yewondwossen Assefa
Sent: Friday, April 01, 2011 2:57 PM
To: mapserver-dev at lists.osgeo.org
Subject: Re: [mapserver-dev] MOTION: Symbol-level keyword removal
+1 to remove them for 6.0.
Note that I will try to revive the discussion around the possibility to
add a simple name style look up mechanism after the 6.0 release.
Assefa
On 01/04/2011 2:55 PM, Daniel Morissette wrote:
> Hi PSC,
> *** MOTION ***
> Removal of deprecated symbology-related keywords in MapServer 6.0:
> 1- Remove any references to CARTOLINE still left in the code and
> documentation. CARTOLINE had stopped working a few releases ago anyway.
> 2- Remove the following GAP, PATTERN, LINECAP/JOIN and POSITION
> keywords from symbolObj with the understanding that they were
> deprecated since around version 5.4 and conceptually those values
> really belong at the STYLE level. (see Thomas' explanation below)
> And I (Daniel) vote +1.
> We've already got formal +1 on this in the previous thread from
> ThomasB and SteveW. A few others have expressed support without voting
> officially.
> So please, PSC members, vote on this motion, and if we get no
> objections by Tuesday April 5 then I will take care of this before
> next week's beta.
> Related tickets:
> http://trac.osgeo.org/mapserver/ticket/3797
> http://trac.osgeo.org/mapserver/ticket/3798
> Daniel
> On 11-04-01 12:47 PM, thomas bonfort wrote:
>> Christy,
>> Supporting those keywords on STYLES and SYMBOLS makes us jump through
>> hoops to try and support it consistently throughout the codebase. I
>> understand the need you have, and would hope that someone comes up
>> with funding for real style inheritance in mapserver.
>> Until then, using gap/pattern on a symbol is conceptually incorrect,
>> as a SYMBOL is just the reference to a marker type, and it is the
>> STYLE that references it that is used to determine how it should be
>> styled for each feature. I agree that the previous version of
>> mapserver did not clearly make the distinction between the two
>> concepts, but that derived due to the limitations of the GD renderer
>> with respect to advanced symbology.
>> As the mapfiles have to be updated anyhow in 6.0 due to other
>> backwards-compatibility breaking changes, now would seem the good time
>> to update them for those keywords too, rather than forcing another
>> change in 7.0.
>> regards,
>> Thomas
>> On Fri, Apr 1, 2011 at 16:44, Christy Nieman<cnieman at dmsolutions.ca>
>> wrote:
>>> I just wanted to put in my $0.02 on this.
>>> I'm a little worried that removing parameters like these from the
>>> symbol
>>> file will make large and complex mapfiles more difficult to manage
>>> without
>>> some sort of named style inheritance (which I don't think exists
>>> yet?). I
>>> have many symbols for line styles that I reuse throughout a mapfile and
>>> having to change gap values, line caps and/or patterns for each
>>> class that
>>> uses the style will make management of the mapfiles a lot more
>>> involved.
>>> Christy
>>> View this message in context:
>>> http://osgeo-org.1803224.n2.nabble.com/6-0-backwards-compatibility-tp6226113p6231271.html
>>> Sent from the Mapserver - Dev mailing list archive at Nabble.com.
>>> mapserver-dev mailing list
>>> http://lists.osgeo.org/mailman/listinfo/mapserver-dev
Assefa Yewondwossen
Software Analyst
Email: yassefa at dmsolutions.ca
http://www.dmsolutions.ca/
Phone: (613) 565-5056 (ext 14)
Fax: (613) 565-0925
