[mapserver-dev] MOTION: Symbol-level keyword removal
Yewondwossen Assefa
yassefa at dmsolutions.ca
Fri Apr 1 16:14:26 EDT 2011
On 01/04/2011 3:59 PM, Lime, Steve D (DNR) wrote:
> +1... Assefa, I have the RFC work on references that Schuyler started around some place.
Great, I will start from that.
> Steve
> -----Original Message-----
> From: mapserver-dev-bounces at lists.osgeo.org [mailto:mapserver-dev-bounces at lists.osgeo.org] On Behalf Of Yewondwossen Assefa
> Sent: Friday, April 01, 2011 2:57 PM
> To: mapserver-dev at lists.osgeo.org
> Subject: Re: [mapserver-dev] MOTION: Symbol-level keyword removal
> +1 to remove them for 6.0.
> Note that I will try to revive the discussion around the possibility to
> add a simple name style look up mechanism after the 6.0 release.
> Assefa
> On 01/04/2011 2:55 PM, Daniel Morissette wrote:
>> Hi PSC,
>> *** MOTION ***
>> Removal of deprecated symbology-related keywords in MapServer 6.0:
>> 1- Remove any references to CARTOLINE still left in the code and
>> documentation. CARTOLINE had stopped working a few releases ago anyway.
>> 2- Remove the following GAP, PATTERN, LINECAP/JOIN and POSITION
>> keywords from symbolObj with the understanding that they were
>> deprecated since around version 5.4 and conceptually those values
>> really belong at the STYLE level. (see Thomas' explanation below)
>> And I (Daniel) vote +1.
>> We've already got formal +1 on this in the previous thread from
>> ThomasB and SteveW. A few others have expressed support without voting
>> officially.
>> So please, PSC members, vote on this motion, and if we get no
>> objections by Tuesday April 5 then I will take care of this before
>> next week's beta.
>> Related tickets:
>> http://trac.osgeo.org/mapserver/ticket/3797
>> http://trac.osgeo.org/mapserver/ticket/3798
>> Daniel
>> On 11-04-01 12:47 PM, thomas bonfort wrote:
>>> Christy,
>>> Supporting those keywords on STYLES and SYMBOLS makes us jump through
>>> hoops to try and support it consistently throughout the codebase. I
>>> understand the need you have, and would hope that someone comes up
>>> with funding for real style inheritance in mapserver.
>>> Until then, using gap/pattern on a symbol is conceptually incorrect,
>>> as a SYMBOL is just the reference to a marker type, and it is the
>>> STYLE that references it that is used to determine how it should be
>>> styled for each feature. I agree that the previous version of
>>> mapserver did not clearly make the distinction between the two
>>> concepts, but that derived due to the limitations of the GD renderer
>>> with respect to advanced symbology.
>>> As the mapfiles have to be updated anyhow in 6.0 due to other
>>> backwards-compatibility breaking changes, now would seem the good time
>>> to update them for those keywords too, rather than forcing another
>>> change in 7.0.
>>> regards,
>>> Thomas
>>> On Fri, Apr 1, 2011 at 16:44, Christy Nieman<cnieman at dmsolutions.ca>
>>> wrote:
>>>> I just wanted to put in my $0.02 on this.
>>>> I'm a little worried that removing parameters like these from the
>>>> symbol
>>>> file will make large and complex mapfiles more difficult to manage
>>>> without
>>>> some sort of named style inheritance (which I don't think exists
>>>> yet?). I
>>>> have many symbols for line styles that I reuse throughout a mapfile and
>>>> having to change gap values, line caps and/or patterns for each
>>>> class that
>>>> uses the style will make management of the mapfiles a lot more
>>>> involved.
>>>> Christy
>>>> View this message in context:
>>>> http://osgeo-org.1803224.n2.nabble.com/6-0-backwards-compatibility-tp6226113p6231271.html
>>>> Sent from the Mapserver - Dev mailing list archive at Nabble.com.
>>>> _______________________________________________
>>>> mapserver-dev mailing list
>>>> http://lists.osgeo.org/mailman/listinfo/mapserver-dev
Assefa Yewondwossen
Software Analyst
Email: yassefa at dmsolutions.ca
http://www.dmsolutions.ca/
Phone: (613) 565-5056 (ext 14)
Fax: (613) 565-0925
