Hi, I discovered a problem in the GetCapabilities output using latest MapServer 6 beta. Tag BoundingBox has a empty CRS/SRS. It's located here ROOTLAYER EX_GeographicBoundingBox BoundingBox CRS="" minx=... The mapfile has a MAP.PROJECTION set, but in msWMSGetCapabilities map->projection is empty. Martin
