[mapserver-dev] Capabilities broken in MS6-beta
Martin Kofahl M.Kofahl at gmx.net
Fri Apr 8 15:25:52 EDT 2011
Interesting - obviously from older epsg versions my map projection setting, which results in <BoundingBox CRS="" minx=...>, is
PROJECTION
      "ellps=bessel"
      "init=epsg:31468"
END
Removing "ellps=bessel" or switching to first init, then ellps will resolve this issue.
Maintainer of maplexer please check that skipping the init value is desired if other keys are set.
Martin
-------- Original-Nachricht --------
> Datum: Fri, 08 Apr 2011 17:16:01 +0200
> Von: "Martin Kofahl" <M.Kofahl at gmx.net>
> An: mapserver-dev at lists.osgeo.org
> Betreff: [mapserver-dev] Capabilities broken in MS6-beta
> Hi,
> I discovered a problem in the GetCapabilities output using latest
> MapServer 6 beta. Tag BoundingBox has a empty CRS/SRS. It's located here
> ROOTLAYER
>   EX_GeographicBoundingBox
> The mapfile has a MAP.PROJECTION set, but in msWMSGetCapabilities
> map->projection is empty.
> Martin
> mapserver-dev mailing list
> http://lists.osgeo.org/mailman/listinfo/mapserver-dev
