[mapserver-dev] Capabilities broken in MS6-beta
Alan Boudreault
aboudreault at mapgears.com
Fri Apr 8 15:34:57 EDT 2011
I'm going to take a look.
Alan
On April 8, 2011 03:25:52 pm Martin Kofahl wrote:
> Interesting - obviously from older epsg versions my map projection setting,
> which results in <BoundingBox CRS="" minx=...>, is
> PROJECTION
> "ellps=bessel"
> "init=epsg:31468"
> END
> Removing "ellps=bessel" or switching to first init, then ellps will resolve
> this issue.
> Maintainer of maplexer please check that skipping the init value is desired
> if other keys are set.
> Martin
> -------- Original-Nachricht --------
> > Datum: Fri, 08 Apr 2011 17:16:01 +0200
> > Von: "Martin Kofahl" <M.Kofahl at gmx.net>
> > An: mapserver-dev at lists.osgeo.org
> > Betreff: [mapserver-dev] Capabilities broken in MS6-beta
> > Hi,
> > I discovered a problem in the GetCapabilities output using latest
> > MapServer 6 beta. Tag BoundingBox has a empty CRS/SRS. It's located here
> > ROOTLAYER
> > EX_GeographicBoundingBox
> > The mapfile has a MAP.PROJECTION set, but in msWMSGetCapabilities
> > map->projection is empty.
> > Martin
> > mapserver-dev mailing list
> > http://lists.osgeo.org/mailman/listinfo/mapserver-dev
