[mapserver-dev] Capabilities broken in MS6-beta
Frank Warmerdam
warmerdam at pobox.com
Fri Apr 8 15:41:44 EDT 2011
On 11-04-08 03:25 PM, Martin Kofahl wrote:
> Interesting - obviously from older epsg versions my map projection setting, which results in<BoundingBox CRS="" minx=...>, is
> PROJECTION
> "ellps=bessel"
> "init=epsg:31468"
> END
> Removing "ellps=bessel" or switching to first init, then ellps will resolve this issue.
> Maintainer of maplexer please check that skipping the init value is desired if other keys are set.
Martin,
I don't believe this is a lexer problem. I suspect it is that when looking
for EPSG init statements we assume it will be the first item in the
projection definition.
PS. I wish folks would stop using the above form and instead do:
PROJECTION
"+init=epsg:31468 +ellps=bessel"
END
Best regards,
and watch the world go round - Rush | Geospatial Programmer for Rent
