[mapserver-dev] v6 beta 4 Cairo PDF and raster
Brent Fraser
bfraser at geoanalytic.com
Wed Apr 13 10:49:48 EDT 2011
Thanks to all involved in fixing the problem
(http://trac.osgeo.org/mapserver/ticket/3799). Shp2img no longer
crashes, but the OPACITY doesn't seem to work. Can someone confirm that?
Thanks!
Best Regards,
Brent Fraser
On 4/1/2011 9:46 PM, Brent Fraser wrote:
> shp2img crashes when rendering a tif into a pdf using:
> MAP
> NAME 'topo'
> # Map image size
> SIZE 800 800
> UNITS meters
> EXTENT 285000 5435000 291000 5440000
> PROJECTION
> 'proj=utm'
> 'zone=12'
> 'ellps=WGS84'
> 'datum=WGS84'
> 'units=m'
> 'no_defs'
> END
> # Background color for the map canvas -- change as desired
> IMAGECOLOR 255 255 255
> IMAGETYPE CAIRO_PDF
> OUTPUTFORMAT
> NAME 'CAIRO_PDF'
> DRIVER CAIRO/PDF
> EXTENSION "pdf"
> END
> LAYER
> NAME '082h04'
> TYPE RASTER
> DATA 'C:\Inetpub\wwwroot\Topo\data\raster\SHADING\08H04.tif'
> STATUS DEFAULT
> OPACITY 50
> PROJECTION
> 'proj=longlat'
> 'ellps=GRS80'
> 'datum=NAD83'
> 'no_defs'
> END
> END
> END
> I'll file a ticket...
