[mapserver-dev] v6 beta 4 Cairo PDF and raster
thomas bonfort
thomas.bonfort at gmail.com
Wed Apr 13 11:24:23 EDT 2011
Brent,
I've just committed [1] two tests for raster data, and pdf supports
opacity. We'll need more info...
ps: don't be confused by the .png extensions, the .pdf.png file is really a pdf
thomas
[1] http://trac.osgeo.org/mapserver/changeset/11555
On Wed, Apr 13, 2011 at 16:49, Brent Fraser <bfraser at geoanalytic.com> wrote:
> Thanks to all involved in fixing the problem
> (http://trac.osgeo.org/mapserver/ticket/3799). Shp2img no longer crashes,
> but the OPACITY doesn't seem to work. Can someone confirm that?
> Thanks!
> Best Regards,
> Brent Fraser
> On 4/1/2011 9:46 PM, Brent Fraser wrote:
>> shp2img crashes when rendering a tif into a pdf using:
>> MAP
>> NAME 'topo'
>> # Map image size
>> SIZE 800 800
>> UNITS meters
>> EXTENT 285000 5435000 291000 5440000
>> PROJECTION
>> 'proj=utm'
>> 'zone=12'
>> 'ellps=WGS84'
>> 'datum=WGS84'
>> 'units=m'
>> 'no_defs'
>> END
>> # Background color for the map canvas -- change as desired
>> IMAGECOLOR 255 255 255
>> IMAGETYPE CAIRO_PDF
>> OUTPUTFORMAT
>> NAME 'CAIRO_PDF'
>> DRIVER CAIRO/PDF
>> EXTENSION "pdf"
>> END
>> LAYER
>> NAME '082h04'
>> TYPE RASTER
>> DATA 'C:\Inetpub\wwwroot\Topo\data\raster\SHADING\08H04.tif'
>> STATUS DEFAULT
>> OPACITY 50
>> PROJECTION
>> 'proj=longlat'
>> 'ellps=GRS80'
>> 'datum=NAD83'
>> 'no_defs'
>> END
>> END
>> END
>> I'll file a ticket...
> mapserver-dev mailing list
> mapserver-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapserver-dev
