[mapserver-dev] v6 beta 4 Cairo PDF and raster
thomas bonfort
thomas.bonfort at gmail.com
Wed Apr 13 11:39:26 EDT 2011
and what do you get with msautotest/renderers/raster_simple_opacity.map ?
On Wed, Apr 13, 2011 at 17:34, Brent Fraser <bfraser at geoanalytic.com> wrote:
> Thomas,
> I'm using the test map file and data:
> MAP
> NAME TEST
> STATUS ON
> SIZE 400 300
> EXTENT 0.5 0.5 399.5 299.5
> IMAGECOLOR 255 255 255
> SHAPEPATH "../gdal"
> IMAGETYPE CAIRO_PDF
> OUTPUTFORMAT
> NAME 'CAIRO_PDF'
> DRIVER CAIRO/PDF
> EXTENSION "pdf"
> END
> LAYER
> NAME grey
> TYPE raster
> STATUS default
> # OPACITY 50
> DATA data/grey.tif
> END
> END # of map file
> When OPACITY is used, the raster data is not included in the PDF.
> Commenting out OPACITY results in a PDF with a raster.
> Best Regards,
> Brent Fraser
> On 4/13/2011 9:24 AM, thomas bonfort wrote:
>> Brent,
>> I've just committed [1] two tests for raster data, and pdf supports
>> opacity. We'll need more info...
>> ps: don't be confused by the .png extensions, the .pdf.png file is really
>> a pdf
>> thomas
>> [1] http://trac.osgeo.org/mapserver/changeset/11555
>> On Wed, Apr 13, 2011 at 16:49, Brent Fraser<bfraser at geoanalytic.com>
>> wrote:
>>> Thanks to all involved in fixing the problem
>>> (http://trac.osgeo.org/mapserver/ticket/3799). Shp2img no longer
>>> crashes,
>>> but the OPACITY doesn't seem to work. Can someone confirm that?
>>> Thanks!
>>> Best Regards,
>>> Brent Fraser
>>> On 4/1/2011 9:46 PM, Brent Fraser wrote:
>>>> shp2img crashes when rendering a tif into a pdf using:
>>>> MAP
>>>> NAME 'topo'
>>>> # Map image size
>>>> SIZE 800 800
>>>> UNITS meters
>>>> EXTENT 285000 5435000 291000 5440000
>>>> PROJECTION
>>>> 'proj=utm'
>>>> 'zone=12'
>>>> 'ellps=WGS84'
>>>> 'datum=WGS84'
>>>> 'units=m'
>>>> 'no_defs'
>>>> END
>>>> # Background color for the map canvas -- change as desired
>>>> IMAGETYPE CAIRO_PDF
>>>> OUTPUTFORMAT
>>>> NAME 'CAIRO_PDF'
>>>> DRIVER CAIRO/PDF
>>>> EXTENSION "pdf"
>>>> END
>>>> LAYER
>>>> NAME '082h04'
>>>> TYPE RASTER
>>>> DATA 'C:\Inetpub\wwwroot\Topo\data\raster\SHADING\08H04.tif'
>>>> STATUS DEFAULT
>>>> OPACITY 50
>>>> PROJECTION
>>>> 'proj=longlat'
>>>> 'ellps=GRS80'
>>>> 'datum=NAD83'
>>>> 'no_defs'
>>>> END
>>>> END
>>>> END
>>>> I'll file a ticket...
>>> mapserver-dev mailing list
>>> mapserver-dev at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/mapserver-dev
