[mapserver-dev] v6 beta 4 Cairo PDF and raster
Brent Fraser
bfraser at geoanalytic.com
Wed Apr 13 11:49:05 EDT 2011
no opacity: PDF with rgba.tif (good)
opacity 50: PDF with yellow background (not good)
Best Regards,
Brent Fraser
On 4/13/2011 9:39 AM, thomas bonfort wrote:
> and what do you get with msautotest/renderers/raster_simple_opacity.map ?
> On Wed, Apr 13, 2011 at 17:34, Brent Fraser<bfraser at geoanalytic.com> wrote:
>> Thomas,
>> I'm using the test map file and data:
>> MAP
>> NAME TEST
>> STATUS ON
>> SIZE 400 300
>> EXTENT 0.5 0.5 399.5 299.5
>> IMAGECOLOR 255 255 255
>> SHAPEPATH "../gdal"
>> IMAGETYPE CAIRO_PDF
>> OUTPUTFORMAT
>> NAME 'CAIRO_PDF'
>> DRIVER CAIRO/PDF
>> EXTENSION "pdf"
>> END
>> LAYER
>> NAME grey
>> TYPE raster
>> STATUS default
>> # OPACITY 50
>> DATA data/grey.tif
>> END
>> END # of map file
>> When OPACITY is used, the raster data is not included in the PDF.
>> Commenting out OPACITY results in a PDF with a raster.
>> Best Regards,
>> Brent Fraser
>> On 4/13/2011 9:24 AM, thomas bonfort wrote:
>>> Brent,
>>> I've just committed [1] two tests for raster data, and pdf supports
>>> opacity. We'll need more info...
>>> ps: don't be confused by the .png extensions, the .pdf.png file is really
>>> a pdf
>>> thomas
>>> [1] http://trac.osgeo.org/mapserver/changeset/11555
>>> On Wed, Apr 13, 2011 at 16:49, Brent Fraser<bfraser at geoanalytic.com>
>>> wrote:
>>>> Thanks to all involved in fixing the problem
>>>> (http://trac.osgeo.org/mapserver/ticket/3799). Shp2img no longer
>>>> crashes,
>>>> but the OPACITY doesn't seem to work. Can someone confirm that?
>>>> Thanks!
>>>> Best Regards,
>>>> Brent Fraser
>>>> On 4/1/2011 9:46 PM, Brent Fraser wrote:
>>>>> shp2img crashes when rendering a tif into a pdf using:
>>>>> MAP
>>>>> NAME 'topo'
>>>>> # Map image size
>>>>> SIZE 800 800
>>>>> UNITS meters
>>>>> EXTENT 285000 5435000 291000 5440000
>>>>> PROJECTION
>>>>> 'proj=utm'
>>>>> 'zone=12'
>>>>> 'ellps=WGS84'
>>>>> 'datum=WGS84'
>>>>> 'units=m'
>>>>> 'no_defs'
>>>>> END
>>>>> # Background color for the map canvas -- change as desired
>>>>> IMAGETYPE CAIRO_PDF
>>>>> OUTPUTFORMAT
>>>>> NAME 'CAIRO_PDF'
>>>>> DRIVER CAIRO/PDF
>>>>> EXTENSION "pdf"
>>>>> END
>>>>> LAYER
>>>>> NAME '082h04'
>>>>> TYPE RASTER
>>>>> DATA 'C:\Inetpub\wwwroot\Topo\data\raster\SHADING\08H04.tif'
>>>>> STATUS DEFAULT
>>>>> OPACITY 50
>>>>> PROJECTION
>>>>> 'proj=longlat'
>>>>> 'ellps=GRS80'
>>>>> 'datum=NAD83'
>>>>> 'no_defs'
>>>>> END
>>>>> END
>>>>> END
>>>>> I'll file a ticket...
>>>> _______________________________________________
>>>> mapserver-dev mailing list
>>>> mapserver-dev at lists.osgeo.org
>>>> http://lists.osgeo.org/mailman/listinfo/mapserver-dev
