[mapserver-dev] testing CLUSTER object
Jeff McKenna
jmckenna at gatewaygeomatics.com
Thu Apr 14 11:03:47 EDT 2011
Hello all,
Just doing some tests for the docs, and I have the following
comments/feedback/questions regarding the new CLUSTER object in
MapServer 6.0:
- why isn't the LAYER TYPE ANNOTATION supported for the cluster object?
A common trick for labelling symbols is to use an annotation layer, I
really think the cluster logic should be applied to that type as well.
- I think there is a problem with query results from a cluster. If I
query a non-cluster-object group of features with mode=nquery (and a
template set at the LAYER level) I get the correct number of features
returned; If I query the same cluster-object group of features with
mode=nquery (and a template set at the LAYER level) I only ever get one
feature result (testing with MapServer trunk). Thoughts?
- If you look at my example layer
(http://www.mapserver.org/trunk/mapfile/cluster.html#example-clustering-railway-stations),
you can see that I had to do some tricks with an expression to not show
a cluster object for when the featurecount = 1; should this be the case?
Would anyone using MapServer ever need a cluster for one feature?
- I've had "challenges" trying to stop the cluster circle symbols from
being split at tile edges with mod-geocache
(http://labs.gatewaygeomatics.com/cluster/demo.html) Yes it could be a
missing setting either in my mapfile or in my geocache.xml, but I still
want to report this. Maybe this is a good sign that we (MapServer or
mod-geocache) need to make it easier for new users to prevent this from
occurring?
Thanks for listening :)
-jeff
Jeff McKenna
MapServer Consulting and Training Services
http://www.gatewaygeomatics.com/
